BEST PLACE TO GET KEYS?
Originally Posted by slvr_s2k,Sep 23 2010, 07:16 AM
cause if you just buying the key, i could help cause i work at coggin (in jaxs) and get a good discount.
Oh I see! I'm right across the street from you at the Auto Body Speed Shop. Are you a tech there? I was just over there a couple of days ago to pick up a 2010 Altima we sent there. I saw your S parked out there, and I'm sure you are the same one I see drive by every now and then.
The standard black key should be about $50 retail (including having it cut.) Having it programmed is usually another $50.
However, from personal experience, yes, the 'accessory' key for the S2000 is over $150! From what I was told ... it is still the most expensive key WITHOUT a FOB from Honda
