Okada Projects Dyno Meet Demonstration Results
#103
#105
#106
One Quick question I cant find the answer to is about Spark plug wear,
I read in an advert "The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM."
So Am I right in assuming the plugs would need to be swapped out more regularly that OEM recommends?
its not a big concern that I would have to replace my plugs more regularly but can I get an idea of if I do and how much more regularly do they recommend I change the Plugs?
#107
Well got a reply back form the okada-projects website and they said the plugs will need to be change out more regularly but didnt give an idea as to how much more regularly.
#108
being f/i i check and change my plugs very often. Maybe every 5K miles and i also have the okada coil packs. Have noticed a little more wear on the plugs but it seems like a small price to pay for my smoother power band. I was having issues with other s2ks on the dyno when pushing past the 600hp mark on the tired factory coils and these definitely helped smooth things out up top. Money wise its all up to the owner if its worth spending it but im happy with them
#110
To get the oem coil cover to work can you remove the red okada disc on the top of each coil ?, are they just a decorative piece on the coils or are they an important part of the coils ?. If they are just decorative maybe I would consider pulling them off and using the oem cover.
I once saw some kind of metal bridge or coil cover with cutouts on it to fit around the okada coils, does anyone know if this part is available ? Thanks for any replies.
