Rotora MINI Brake
Old 05-02-2007, 01:58 PM
kenyellows2k's Avatar
Here's the specs if someone can tell me it will fit stock wheels.
From the middle to the top of the caliper it requires 170mm, from middle to the bottom it requires 90mm of clearance and most importantly it requires 35mm to clear from the side or thickness.
35mm = 1.37inch of side thickness from rotor to the rim. My current Volks CE28 has 1.8 inch of side clearance I will give this a try, looks like it will work without spacers.
Old 05-02-2007, 02:15 PM
zbrewha863's Avatar
Huh, that's weird ... the press release says they make a front and a rear kit for the S2000, but Hopup only sells the front kit.
Either way this is a way better deal than the Spoon kit, the Rotora kit also comes with braided lines and pads. And with the Spoon kit don't you have to buy the hardware separately as well?
Old 05-02-2007, 02:48 PM
Former Sponsor
GT Motoring's Avatar
Spoon kit comes with calipers, and mounts. They use oem brake pads and lines. Looks like a great option for the money. One big difference, is Spoon is Monoblock, these are 2 piece. They should work pretty good regardles tho. (even tho these arent JDM, and this is the JDM section)
Old 05-02-2007, 04:20 PM
leester01's Avatar
No spacers!
Old 05-03-2007, 11:49 AM
Former Sponsor
Originally Posted by leester01,May 2 2007, 04:20 PM
No spacers!
i think they only confirm fits stock DIAMETER wheels, didnt mention offset yet. be awesome if they are more wheel friendly.
Old 05-04-2007, 07:15 AM
tantheman's Avatar
On the look out for rear BBK set up that would work in conjunction with the E-brake.
Tan
Old 05-04-2007, 09:15 AM
Dark's Avatar
incorrect, the mini-4 is a monoblock 4 piston caliper.
Old 05-04-2007, 09:31 AM
Guerillah's Avatar
Looking at the picture of it, it does not appear to be monoblock. You can see its two sides and bolts holding it together.
Old 05-06-2007, 11:49 AM
Dark's Avatar
my mistake, by monoblock I meant it wasn't a pull-style like the stockers.
Old 01-31-2010, 06:27 PM
akilbrid's Avatar
Originally Posted by Tolgahan Ures,May 2 2007, 12:10 PM
Do they fit ap2 version 1 rims without any spacers ?
I would love to know the answer to this question.
Quick Reply: Rotora MINI Brake
