Axle Nut TSB - Sharing my Tools
Tightening the nut to the next flat is what's required. Of course you need to know the start point. But you don't need a torque wrench, just a big breaker bar and 36mm socket. 180 pounds on the end of the 2-foot wrench handle should be enough. Maybe bounce a bit.
Remove the nut (the stake will come off as you loosen), clean and grease the nut, and replace to where it was. Tighten one more flat (another 60° since there are six sides). Re-stake.
-- Chuck
-- Chuck
yeah, it looks like you didn't quite turn the nut far enough. as chuck mentioned it should go 60 degrees(1/6 of a turn) past the starting position. looks like you went 1/12 of a turn.
Originally Posted by #172CR' timestamp='1473519207' post='24058985
[quote name='Wobster' timestamp='1472350654' post='24049321']
Is this for all years or limited to certain years? Did Honda ever issue a tech bulletin on this or is it something Billman just learned through experience?
Where did you see Billman estimated ft/lbs that high? Getting the stake point moved from a start point (12) to (2) has been adequate for most owners.
[/quote]
Gotcha! I bet the torque spec's vary quite a bit depending on each car and getting that dang nut moved 1/6th of a turn!
Well fawk by bearings and most likely hubs are toast. Originals on 174K and just started hearing dubstep as background music
Any recommendations on local shops for a press in the metro area? I can disassemble myself, just don't have a press
Originally Posted by arsenal
Well fawk by bearings and most likely hubs are toast. Originals on 174K and just started hearing dubstep as background music Any recommendations on local shops for a press in the metro area? I can disassemble myself, just don't have a press
Some machine shops will do the work and sometimes you can slip into a transmission shop to get a little time on their press. I was frustrated when the manager at the place I wanted to use decided he wanted a minimum of two hour shop time (@ $74 per hr) for each visit. So I went to Harbor Freight with a coupon and bought a press at a little over $100. Mine is not easily accessible and since it has to be dragged in and out of the garage for use I don't offer it, but if you have the room you can buy a press.
Kel
27
05-26-2006 09:50 AM
wantone
10-12-2002 09:46 PM
