S2000 Body and Paint Body kits, paint, ding repair and related discussions
Removing Rear Moulding Around Top
Old 12-27-2016, 02:59 PM
freq's Avatar
Question Removing Rear Moulding Around Top
Any issues removing this trim / moulding from around the soft top / hard top area?
Not sure why but it's making me pause.
#16 in the image below.
Old 12-27-2016, 03:20 PM
Hfreak's Avatar
Pretty straight forward if you are soft top delete, much more complicated otherwise.
Old 12-28-2016, 03:56 AM
freq's Avatar
I worded that wrong, it's not the removal that concerns me. It's the re-installation and getting it to look decent that concerns me.
Soft top and everything behind the dash is gutted.
Old 12-29-2016, 06:43 PM
vasquezgno's Avatar
Tried to purchase that piece and it was on back order but it looks pretty straight forward the installation process
Old 12-30-2016, 03:37 AM
freq's Avatar
I can imagine shipping that piece would be a total bitch.
There is a piece of foam that run the entire length, it gets folded over the edge of the body then the molding goes over that to avoid rubbing I guess.
I'm hoping reinstallation won't be too bad.
Old 12-30-2016, 05:05 AM
Hfreak's Avatar
The foam is attached to the molding but could be stuck to the body of the car in various locations, at least mine was. If you remove the molding with care the foam will be reusable. Installing the molding is fairly easy as there are mounting holes with very little adjustment, I pressed down lightly on the molding while tightening the bolts.
bgoetz
01-17-2018 10:10 AM
notaloafer
10-23-2013 06:03 PM
Whoabitchin
03-23-2010 12:52 PM
L2thousand
01-03-2010 10:19 AM
fastolbat
08-22-2009 10:26 AM
Quick Reply: Removing Rear Moulding Around Top
