60mm springs and 2.25 in. Perches?
My coilovers have perches specifically for 2.25" springs, and I want to buy some Swift springs. The closest to the 2.25" is the 60mm which = 2.36". Has anyone tried this and can confirm they fit?
TIA
TIA
I used nylon or fiber reinforced plastic adapter rings to adapt my 60mm perches to 2.5" when I ran Hypercos. If you dig around through some of the places like Hoerr or Summit you may be able to find rings that will convert the 2.25" to 60mm. When I switched to Swift I switched perch to perch to 60mm.
Thanks for the info guys. imstimpy that's a good idea. I'm going to try to find out what the coilover thread size is. H&R has 60mm perches. Sakebomb, once I got it figured out, I'll shoot you a PM. Otherwise I'll probably just stick with Eibach or Hyperco 2.25." Do you carry either of those?
Sorry for the delayed response, it's been busy due to Black Friday and the holiday so there hasn't been a ton of time for the forums. We generally have 65mm swift springs but can order from eibach as well and have them drop shipped to you. Shoot us a PM with the diameter, rate, and length you are looking for and we can see what's available.
-Greg @ SBG
-Greg @ SBG
mustangkiller01
Member S2000 Classifieds and For Sale
08-05-2004 02:40 AM
