AP2 alignment specs? - S2KI Honda S2000 Forums
LinkBack Thread Tools
Old 02-02-2010, 07:40 AM   #1
Default AP2 alignment specs?
Does anyone have the Honda recommended alignment specs for the AP2? (search is down so I couldn't use that function)
Black Knight is offline   Reply With Quote
Old 02-02-2010, 09:07 AM   #2
Not sure of the specs, though if the search is down you can search from google.com by entering the info below.
alignment specs site:http://www.s2ki.com/forums
John
GPW AP2 is offline   Reply With Quote
Old 02-02-2010, 10:06 AM   #3
Member
SilverS2kF22C1's Avatar
Specs I plan on aligning the car to in the spring.
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
rear camber -2.0
rear toe 0.20 total 0.40
SilverS2kF22C1 is offline   Reply With Quote
Old 02-02-2010, 10:23 AM   #4
UK Alignment Specs
front castor 6.45
front camber -1.0
front toe 0.0
rear camber -2.0
I'm just wanting to align to US specs....anyone know those?
Old 02-02-2010, 11:22 AM   #5
pretty sure the only difference is that US spec is 0F -1R for camber, all else should be the same.
regardless, the alignment shop will have the us specs. i persoanlly run us spec even though i run huge tires and lowered. i hate the uk spec. extra camber recked tires unevenly.
camuman is offline   Reply With Quote
Old 02-02-2010, 11:40 AM   #6
exactly why I don't want to run UK spec
Old 02-02-2010, 11:48 AM   #7
Member
spets's Avatar
AP2 spec has only .25 total toe, not .40-.5 like AP1/UK spec.
I run UK spec camber but US AP2 spec toe.
spets is offline   Reply With Quote
Old 02-02-2010, 11:50 AM   #8
How long would you all wait to get an alignment done after installing lowering springs?
Old 02-02-2010, 12:01 PM   #9
Are you sure you didn't have some other problem with your alignment somewhere? An extra degree of camber should have a negligible effect on your tire wear, unless there's an underlying problem.
rail157 is offline   Reply With Quote
Old 02-02-2010, 12:29 PM   #10
2* camber is no big deal. Excessive toe causes a lot more wear than modest camber, mine's maxed out at 2.2* in back and the rears wear evenly across the tread.
ZDan is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
WTB: JDM wiring loom LiamR UK & Ireland For Sale and Wanted 1 01-12-2017 04:14 PM
FS: 2002 S2000, GPW red/black interior RIDGERCR Upstate New York Classifieds 23 01-06-2017 07:02 AM
Fs: Ny --gpw ap1 $18,000 obo RIDGERCR Cars for Sale 14 01-06-2017 06:25 AM
How would my ap1 benefit from a front sway bar Xeon S2000 Modifications and Parts 14 11-28-2016 07:30 AM
Wtb tires 255/40/17 jr94513 Bay Area For Sale 3 11-23-2016 11:35 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
