DIY: Brake Bleed (Gravity Method)
#21
Is this a repost of the original gravity bleed DIY that has been around for years? Or a new one?
Personally, I have used both this method and a vacuum pump. In the winter, you have to use a pump or it will literally take all day to bleed the rears. The cold makes the fluid too thick. But if it is warm enough, this method works great.
#23
#27
Just finished! Lmao took forever... but the sight of that blue fluid coming out of the bleeder is so satisfying haha ...I ended up closing it and going out for a drive like someone suggested. Helped a little bit.. then I noticed that the mouth of the house was a little stretched so I cut a new fresh piece and that fit on tighter and sped up the process for some reason. I also kinda messed up the order.. I went front pass, front driver, rear driver and then rear pass. Shouldn't be a problem I hope.. about to go for a test drive!
EDIT: everything looks great. thanks for the write up!
#29
do you recommend this method over a two person pump session hehe. I heard with pumping, you can wreck the master b/c the master isn't use to being pressed that far. so do you think gravity is better.
#30
If you have the patience then do gravity.
