Sponsored by: Sake Bomb
hks hipermax gt vs koni yellow/gc vs bilstein pss9
Old 11-07-2016, 03:15 AM
bgoetz's Avatar
Originally Posted by SamySnead
So confused by this thread. First, you stated you want cheap and nice riding. And no intention on tracking the car. PSS fit the bill. Not sure why you're set on custom valving/springs just for street use..?
I think PSS are too soft for what he is after. Custom valving allows him to take two inexpensive setups and have them valved for stiffer springs, which will result in a stiff yet streetable setup for only a couple hundred $ more than the PSS. The new vs used thing is irrelevant as once revalved they are essentially a new shock only valved better. Not sure about the PSS9s, but my yellows only have 10k on them and need rebuilt because they leak around the adjusters on two, so technically they are not blown. The leaking is my fault because I was careless with the wrench!
Old 11-08-2016, 03:47 AM
UK Moderator
lovegroova's Avatar
That I know of, Konis are not used in top tier motorsports; however, for amateur use, they will get the job done and will do it well for performance use. However; there are limitations to what a Koni damper can do - don't expect to get both excellent street characteristics with excellent track handling - it's one or the other, not both. That's what really separates higher end dampers, capable of more digressive valving, from lower and middle level dampers - their valving can handle a broader range of springs and maintain a compliant street ride while still offering on track performance.
Good luck with the choice, you should be happy with either the Koni or Bilstein setup. They'll be a nice improvement over the OEM showa dampers (which are also quite good - wish they could be opened up and revalved).
Koni supply dampers to the Force India Formula 1 team, so certainly participate in top tier motorsports, more here: https://www.koni.com/About/KONI-s-racing-history/
I loved the PSS9s on my old S2000, I ran them as standard and worked superbly well on the road (I ran 6 clicks out of 9 from the stiffest setting - the roads in the UK are terrible) and were adequate for the odd track day where the stiffer settings were an improvement over the road settings.
Old 11-18-2016, 03:00 AM
nicostatus's Avatar
I own the HKS Hipermax IV GT. When I was shopping for coilovers, I researched heavily and it came down to these or the Ohlins. I have taken my car to the track and I plan to some more in the future, but 95% of the time my car is daily driven on public roads. I definitely had the budget, but at the end of the day I couldn't justify paying the price premium for the Ohlins vs the HKS for the type of driving I do. When these wear out, Ohlins are next, so that I can compare the real world differences between the two. It's hard to go just off of opinions, since everyone's tastes differ.
As far as my satisfaction with the HKS coils goes.. I Love them and they perform great for my needs. The drop out of the box is perfect in the rear (2 finger gap from top of tire to fender), but it sits higher in the front. I lowered my front to one finger gap because I like a little rake. Out of box stiffness is set right in the middle and it rides "softer" than stock, but the body roll is not increased if that makes sense. I stiffened mine up to 20 clicks out of 30 and this is the perfect amount for street driving, for me at least. Body roll is reduced by a great amount and it helps you really feel confident in pushing the car through corners, while still maintaining a decent amount of ride comfort.
If all you are looking to do is to slightly improve the vehicles dynamics over stock and to slightly lower it, I recommend these 100%. Hope this helps! Here's a pic of one of them installed.
hks hipermax gt vs koni yellow/gc vs bilstein pss9-62z0e2ym.jpg
xxyion
02-12-2019 02:31 PM
Xeon
02-09-2017 04:36 PM
NFR-S2k-
11-06-2016 06:17 PM
Ham8urger
02-16-2016 07:03 AM
JCCs2k
09-22-2015 07:55 AM
Quick Reply: hks hipermax gt vs koni yellow/gc vs bilstein pss9
