Official Stoptech BBK Wheel Fitment Thread
Bronze Volk Racing CE28N. Longer studs and a 13mm spacer at the fronts are required for the following setup.
Front: Stoptech Big Brake Kit 328mm x 28mm (Stoptech AeroRotors vented with Stoptech 4-Piston Calipers)
Rear: Custom Brake Setup 322mm x 17mm (Custom AeroRotors vented with modified OEM Calipers)
Front size / offset of the wheels: 17 x 7.5 JJ / Off +50
Rear size / offset of the wheels: 17 x 9.0 JJ / Off +63
Here are few shots when I used to have the red extended lug nuts by Rays Engineering. I've replaced them couple of month ago with the black edition. I had to replace them to match my carbon fiber hood.
Originally Posted by petawabit,Jun 30 2010, 02:08 PM
nice, you didn't sell them!:P
Brian
Originally Posted by Torqueless,Apr 9 2010, 03:47 PM
Enkei RPF1s
17x8.0 +45
Stoptech 328x28mm Kit
No spacers
BARELY clears
17x8.0 +45
No spacers
BARELY clears
Originally Posted by az3ar,Jun 30 2010, 05:53 PM
Would you know if the 9 inch wide RFP1s 45s would fit?
^yup
the only offsets that accommodate a BBk for the enkei rpf1s are the 17x8 +45 and even then i would add a 3mm spacer just to be safe.. i'm less than a credit card's clearance right now
