SS Braided Lines - Poor Pedal Feel and handbrake light on
#21
Just as an update: i tore a ligament in my ankle playing basketball and have been on the couch for the last week and half... Car has sat in the garage.
@sake - Did it with a friend. Once i recover i hope to have a more knowledgeable friend assist with the bleed.
#22
Another update:
Credit to Z32MadMan for mentioning the procedure and Billman for the actual procedure. I was amazed at the result of doing this. This is definitely the stiffest (obligatory "that's what she said") pedal feel i have ever had with the car in the 6 years of ownership.
Just completing this alone produced an amazing pedal feel.
I then drove around trying to engage ABS... This is really hard to do on 255 AD08Rs...
I completed a gravity bleed with about 1/2 a litre of fluid but there really wasn't any air in the system.
Bad news is that my handbrake light is still on. I will probably repeat this procedure again next weekend and if that doesn't clear the warning, i'll go see a professional.
#23
Your handbrake light is not directly related to air in the system. Its not an air detector.
The float in your brake fluid reservoir cap is probably the issue.
#24
So finally this is resolved - the float in my reservoir was stuck at the bottom. Most likely this occurred when i removed the fluid with a turkey baster.
I cleaned up a little flat head screw driver and manually pushed it back up and its sitting happy at the top.
Thanks to everyone for the help and info.
