S2000 CR Club Racer Edition CR stands for "club racer," conjuring up the good old days when guys drove their sports cars to the track, raced them, and then, if the racing gods were smiling, drove them home again
2piece rotors
Old 03-26-2013, 08:33 PM
takchi's Avatar
This is the biggest thing that concerns me about 2-piece rotors, however, when setup right, Wilwoods are good BBK for how compact they are.
Old 03-26-2013, 09:51 PM
odb812's Avatar
Do you know what kind of tires were on this car?
Old 03-27-2013, 08:05 AM
psychoazn's Avatar
RS3 that day.
This type of failure is eliminated with the design of the AP Racing "Sprint" kit...
Old 03-27-2013, 09:00 AM
odb812's Avatar
Originally Posted by psychoazn
RS3 that day.
Could you explain a little more about how it's fixed with the sprint kit? Do you know what brand the rings that failed were? I have two-piece rotors and now this has me a little spooked.
Old 03-29-2013, 04:30 PM
TheSnail's Avatar
I got a new Wilwood 6piston BBK with two peice rotors/ brackets/ pads and hardwear for mine. Summit Racing had the best deal by far @ $14XX for what retails for 1900+. I have been on this BBk for about 15k, and I will say, that if I had the traction to do so, I could stop a train. Here is a snap shot on my cr.
-Snail
Old 03-30-2013, 10:33 AM
takchi's Avatar
Originally Posted by psychoazn' timestamp='1364400336' post='22432053
RS3 that day.
Essex AP Racing kit
http://www.essexparts.com/shop/compl...000-10097.html
Wilwood Dynalite 4 piston BBK?
http://www.partshelper.com/product_i...roducts_id=315
This is just speculation since I don't know EXACTLY how the Wilwood BBK is designed, but from how the hat is mounted, the tab significantly protrudes from the rotor. When the rotor is loaded, there is a significant moment applied to those tabs. With limited stress relief on the mounting tabs, this caused the rotor to flex and fail due to fatigue. I don't think it is a metallurgy issue (I assume Wilwood does a decent job with their QA). Car was only running RS3s too. I assume 255/40/17 or 265/35/18 or even 285/30/18. Either way, that's not enough grip to justify the damage. Anyways, just speculation on my part.
Old 04-01-2013, 11:01 AM
adrs2k's Avatar
Originally Posted by odb812' timestamp='1364403607' post='22432234
[quote name='psychoazn' timestamp='1364400336' post='22432053']
RS3 that day.
Essex AP Racing kit
[/quote]
Just compare the two kits and its easy to see the difference in the rotor and how its mounted to the hat. They are very different and I think you are right David.
I had always though that the Willwood kits where the lightest kits out there and were best used for street and autocross, not heavy track use as they are not as durable as a kit like AP, Stoptech, Brembo.
Old 10-19-2016, 03:19 PM
XiFan-LSY's Avatar
-Snail
Old 10-19-2016, 03:20 PM
XiFan-LSY's Avatar
does wilwood bbk can fit rpf1 17x9+45?
dsddcd
05-29-2012 09:29 AM
robrob
11-13-2009 07:57 AM
gpw04
04-07-2007 11:45 AM
qk2000
79
11-21-2003 02:50 PM
Quick Reply: 2piece rotors
