MY HPDE Track Build - Biohazard
#53
Hello all, still hanging on the site as many of my friends still have their s2k's and we hit the tracks together. Here is an update of my replacement for the CR.
Updated Mods so far:
Suspension:
*MCS (Motion Control Suspension) 1-Way Non-Remote (1WNR) Single Adjustable Damper Set with hyperco coils 600 and 700 and ground control camber plates and adjustable rear perchs.
*Rogue engineering performance FCAB
*Front Strut reinforcement plates
*OEM RCAB with BimmerWorld Trailer arm limiters
*AKG Sub-frame reinforcement
*Hotchkis front adjustable sway bar
*Rogue Engineering Front Racebrace
*ECS adjustable lower control arms
*AKG Differential and Subframe bushings 95A
*TMS bump stops for steering rack
Brakes:
*Stop Tech Trophy Kit ST-60 front and ST-22 rear
*Stop Tech SS lines
*Pagid RS29 Yellow Pads
*Motul RBF 600
*Hard MotorSports Brake Ducts
*Hard MotorSprorts 355mm backing plates
*Bimmerworld high temp brake duct hosing
Cooling:
*New OEM hoses
*BMW motorsport thermostat
Motor:
*LiquiMoly and Motul fluid replacements for whole car
*AFE intake elbow and drop in filter
*Rogue engineering Octane short shifter kit
*Oil cooler divert valve
*Bimmerworld track motor mounts
*Bimmerworld sport Reinforced Urethane Transmission Mount Set
*SS clutch line
*magnetic drain plugs
*Status gruppe section 1 with rasp eliminators, section 2 resonated, exhaust with black tips
*Status gruppe version 3 headers
*Epic Motorsport Race tune
Wheels and tires:
*Bimmerworld race bullet nose studs and lug nuts
*Apex ARC-8 18x9.5 + 35 (Black)
*Apex 12mm spacer for rear and 5mm for front
*NT 01 275/35/18 (dry track conditions)
*2nd set of ARC -8 (Hypersilver) with Michelin Pilot Super Sports for rain 265/35/18
Exterior:
*flat black kidneys
*flat black gills
*Bimmerworld Tow Straps
Interior:
*Sparco 330 steering wheel
*Momo hub
*Rogue Engineering Quick Release
*OMP HTE Halo bucket Driver
*OMP WRC Bucket Passenger
*Schroth Profi II for hans harness driver and passenger
*Vac Motorsports seat mounts with submount and fire exitinguisher
*Raven Performance Bolt in 1/2 cage/roll bar
*BMW Arm rest delete console
*AKG Pedal kit
*Broadway mirror
It was 100% stock,
now it is not.......
Brett's BMW ///M3 (E46) @ Roebling Road flyby 3 - YouTube
Suspension:
Brakes:
*Stop Tech SS lines
*Motul RBF 600
Cooling:
*New OEM hoses
Motor:
*SS clutch line
Wheels and tires:
Exterior:
*flat black kidneys
*flat black gills
Interior:
*Momo hub
*AKG Pedal kit
*Broadway mirror
It was 100% stock,
#54
So I still hang with the S2K group in Orlando even though I am in the M3.
I just updated my HPDE build and photos.
Here is a pic from Daytona in April
#56
It is alot heavier, although I have shaved 300 lbs out of it. The turnin was very sloppy compared to the CR but I was able to clean it up with solid front control arm bushings and a square set up. It is alot of fun on the higher horsepower tracks with long straightaways as torque is needed out of the corners. I can now keep up with the majority of the porsches.
When it comes to running smaller fast sweeping momentum tracks, the CR is way better.
The overall platform of the E46 chassis is way more stable and predictable than the s2k. So I am no longer wondering when the ass end is going to step out on me. Overall I am really enjoying the car and with the red-line set at 8200 on the M3 it is close but not exactly like revving out the CR. I have driven alot of cars and the S2K and S2K CR are definitely special cars and I will probably try to add one again as a weekend fun car.
#58
, it was all about finding an unmolested low mileage M3. That way I knew what I was starting with. The E46 M3 world is very similar to the S2k one with several molested versions found everywhere. Proper maintenance for any high revving vehicle is key to a long and healthy life. I really wanted Alpine white or laguna seca blue but almost impossible to find.
