Car radio/volume buttons on dashboard stopped working
Hi Everyone,
Does anyone know why the volume buttons and car stereo buttons on dashboard near the steering wheel have stopped working, I haven't got a clue where the fuse would be, with luck that is the problem, none of the buttons are working. Does anyone know what I could do to troubleshoot.
Many Thanks
Tobes
Many Thanks
Tobes
Hi Chuck,
Thanks kindly for your reply, I just went and took a couple of photos and ironically found another load of fuses under the steering wheel. lol, Ive attached a couple of pics, none of this buttons apart from the start button work, any idea what fuse they could be, I am guessing its a fuse issue, I hope so would be easy to fix.
Yeh its an OEM radio, still working fine. Thanks for your advice
Btw while I have you here chuck, you wouldn't be able to advise on the fuse I am looking for in this thread: https://www.s2ki.com/forums/s2000-ta...ights-1213069/
Could it be running light, or small light. Yes I know I should just go pull one out and see lol, didn't realise there was more fuses hidden until just now... ooooooops its my dads car who sadly passed away and lucky me left me his car which I will cherish for life.
Cheers
Cheers
reach up through the back and see if you feel the plug properly in. there are two back there, one for the start and one for the dash controls.
if your hand doesnt fit stick your phone under the dash with the flash light on and snap a pic.
If the mute led doesn't light and the backlighting for all the buttons does not work when the lights are on(and dimmer turned up) then I'd be checking the ground.
Are the radio controls the only thing not working?
As with any electronics (home, computer, audio, music studio, car)... "re-seat" the plug a few times first. This will scratch off any corrosion. If that doesn't fix it, check fuses. If that doesn't work, then it'll be a deeper problem.
I Believe the only button that uses 12v is the mute . The others use a ground and resistance.
Pic below, is it Stock? Either way Is it easy to remove, I was wondering the same as you! Thanks
Thanks everyone
Tobes
