Double Din in stock location. Help!
Disclaimer: I'm a car noob.
I've decided not to cut my dash to install my double din. I would like to fit it into the stock location. It seems easier to do than cutting the dash. I know the SRS ECU might have to be relocated. I've read someone was able to fit it in front of the shifter below the carpet without splicing any wires. The problem is I don't know where I can find a bezel that would look good and mounting brackets. Can someone guide me in the right direction. I've been googling fabricators with no luck.
Received 1,553 Likes
Forget the double din and use your phone for the interface via bluetooth. Install a flex stalk phone holder that mounts to the pax seat bolt so it is not in the way. You can close the radio door and do everything on the phone; I have a note so it is plenty big enough.
whitebrad25
09-04-2016 07:28 PM
