Can't find A30 pin for Kpro
If your O2 sensors were disabled you wont have a functioning closed loop operation.
But go ahead and upload your tune and we can take a look if there's anything that looks weird.
heres the tune that's on my ecu right now. keep in mind I have a hondata boost controller that's disabled, wideband isn't pined to ecu, 02 sensors disabled, no timing adjusted, ac was disabled, he basically just made the car run and that's it. afr creeps to 12.5 at wot on boost yeaaaaaa no thank you. the forum wont allow me to upload that file. whats your email?
The s2000 kpro has some unique parameters vs kpro on other cars. Are these the settings that You're referring to??
https://www.hondata.com/kpro-s2000
"KManager Configuration. The following parameters should be used in KManager:
- Use only PRA ECU calibrations (PRA ECUs are the only ECUs which support a narrowband primary oxygen sensor).
- Disable the immobilizer.
- Disable VTC.
- Disable the multiplexer.
- Select 'Use alternate AC switch input'.
- Select 'Use Secondary Oxygen Sensor for Primary'."
- Disable VTC.
I had a look now and I agree it seems the tuner didn't really know what he was doing, or maybe didn't care.
First of all, you are using a PRB type calibration. I'm not sure what cal was used to start off with but it's not a S2000 so many settings are wrong.
AC clutch switch like you said, lots of fuel compensation settings, ELD sensor and all O2 sensors disabled making it run in open loop all the time.
I suggest you start over with the included S2000 ap1 calibration and change whatever needs to be done like injector settings etc.
Fuel and ignition tables you can copy and paste the whole table, you can run two instances of kmanager which makes it pretty easy.
Sorry to hear. It is very important to find a trust worthy tuner. Most take the short cuts and they are not interested in doing the extra stuff for free, even though it is incredibly easy to setup with Kpro. Well, its easy to seup, but you have to confirm it works. I have had very good luck with my Kpro setup.
Id like to see the build thread when it is done.
You can upload it to the post i think, or you could email it to someone if you wanted.
