Evans Tuning e-tune review
Old 10-12-2011, 07:33 AM
  #21
//steve\\'s Avatar
I imagine is all using the datalogs. Obviously you can't get be so aggressive without having the car on a dyno but a street tune should be good enough for you to go out and beat on the car all your want you'll likely just be leaving some power on the table. I know not all setups are identical but for the most common ones I know there are generally known limits and best guesses at where ignition timing should be.
Old 10-13-2011, 04:05 AM
  #22
xredjar's Avatar
Pretty much spot on with this ^^. I had a custom tune done by E-Tunez and from reading this thread....it sounds like they both approach it the same way. Without being on a dyno, your not going to get "spot on" with the ignition, and for just a street tune...being a little conservative is best. May be leaving a little bit of power on the table, but I'd rather be safe than sorry.
Old 10-18-2011, 05:15 AM
  #23
liquidgsr's Avatar
Im definately looking into getting a E-Tune done next...I talked to xredjar about it for a bit and its going to my next move...I will keep this one in in mind. Thanks.
Dizings2k
05-18-2020 11:19 PM
purekoryo
03-04-2011 08:18 AM
foolycooly
Car Talk - Non S2000
10-31-2009 01:46 AM
thecbrman
10-26-2006 07:58 PM
Quick Reply: Evans Tuning e-tune review
