Gernby eTune review - single best 'mod' available for 06+ S2000s
Old 07-03-2013, 07:49 AM
Sylvan's Avatar
This sounds awesome, and may end up being my first mod. Are there noticeable gains in torque/drivability if the stock cat is left in place?
Old 07-03-2013, 01:07 PM
Syn
Syn's Avatar
With the stock cat in place you'll be limited to something like a 5500-5600rpm vtec engagement. If you were to get a tune by Gernby I'm sure you'd see gains because the tune would be tailored to your car specifically.
I would highly recommend getting a testpipe, or at least a high-flow cat if your state does smog and/or you personally don't want to run a catless car. The difference you'll feel over stock with a properly tuned car that switches to the high cam in the mid-3000 rpm range is huge. With a high-flow cat you might not be able to go quite as low as 3600 (I'm betting Gernby knows) but it should still yield significant gains over a stock cat if you're going to spend the time/money to get it custom tuned.
Old 07-08-2013, 03:28 PM
s2kLINT's Avatar
Where is Gernby the great located? I'm in socal
Old 07-16-2013, 07:27 PM
davidnyc's Avatar
He is here in North Texas.... I will be getting a tune from him shortly, once my Hondata arrives.
Old 07-17-2013, 07:27 AM
pmptx's Avatar
You can do the etune by sending him the data logs from the pulls he specifies and then he can work his voodoo magic and will send you the tune. He is really good because he will work with you to assure it is right.
Old 09-22-2013, 06:48 AM
Syn
Syn's Avatar
Bump for anyone considering Flashpro.
Edit: Might as well add some more information while I'm here--
I have been running Gernby's tune all summer and the car is still running flawlessly. Even in the extremely hot 90+ degree days of August the car has pulled much stronger than in previous years.
I would again HIGHLY recommend anyone with an 06+ to consider Flashpro and a Gernby tune.
Old 09-22-2013, 09:18 AM
Former Sponsor
Gernby's Avatar
Thanks!
Old 09-29-2013, 03:03 PM
KwantumFizzics's Avatar
Nice, a lot of positive comments.
I'll be going the Hondata Flashpro route soon and will definitely hit up an etune from Gernby!
Old 12-12-2013, 03:14 AM
Snake_s2k's Avatar
My EURO map, made by Gernby, works fine (on street and track). Nothing to say if not that he did a great job.
Thanks
Old 12-13-2013, 07:49 AM
Nik2k's Avatar
gernby! excellent coments about your tune bro! i have an ap2 2007 ! im installing all the bolts on this weekend! ( exhaust testpipe, cai aem v2. BC stage 2 cams) and i will need to tune! here in ARGENTINA. have 1 tuner i dont trust very much! i will ned you! thanks a lot !
Quick Reply: Gernby eTune review - single best 'mod' available for 06+ S2000s
