greddy emanage ultimate AP1 tune
Its the 00-01 that have the richest tune, but thats across the entire rpm band, not just the top end. The tune sweep looks acurate, but not running a 02 ecu i cant say hoe much further they leaned up top. Probably should just 0 out or cut in half at least.
The dada logging overall is pretty poor on the emanage with its low frame rate. I used it as a loose guidline, and relied more on my aem ugeo wideband and did not monitor knock at all. I used a inline motorcycle fuel filter on the pressure line/switch to help dampen the frequincy spikes for pressure on data logging. Seemed to help some. Basic coolant and iat and other things were nice to have and seemed pretty accurate.
That GEMU tune I posted was from an 01 car so that's why it worried me since I have an 02.
You said iat and coolant temp was good, did you log that in the GEMU or separately?
