Haltech's Honda S2000/AP1 PRO Plug-In ECU
Old 06-11-2011, 05:23 AM
b.r.i.a.n.'s Avatar
Originally Posted by Kyushin
Looks like this is equal to Kpro and better since it has wideband support! I will definitely be switching if it measures up
aem also has wideband support. i used to have kpro on my civic si. one of the things i didn't like about it was the fact that closed loop operation can only be done with the oem wideband. if you used a aftermarket wideband you would need to run open loop. an aftermarket wideband would be used for datalogging purposes and nothing more.
i'm using the haltech ps1000 on my s2k and i bought the haltech dual channel wideband as well. so far so good. closed loop operation works great.
Old 06-11-2011, 07:20 AM
sunman's Avatar
looks like you get to retain obd2? is that correct?
please let us know how idle/startup and cruising operation are.
Old 06-11-2011, 04:01 PM
S2kAndTheAnt's Avatar
According to Evans in the other thread, it does retain some odb2 functions, but with an engine light, and does not present readiness for emissions testing.
Old 06-14-2011, 08:34 AM
sunman's Avatar
^ yeah, I did read that. Can you elaborate on that TS when you have tested the unit?
Old 06-16-2011, 09:21 PM
s2kslav's Avatar
Damn after 11 years, ems options just aren't that great, function and cost wise. Inhale the PS1000 and love it, just hate not knowing if some sensor is going off and messing with something, before it's too late. This doesn't seem to be an ideal solution. Maybe after a few years of trial and error.
Old 06-22-2011, 06:17 AM
josh7owens's Avatar
someone already makes a plug and play for the 500, although I'm not sure who it is. I got a pm not to long ago from a member talking about it but it seems I know longer that that PM. Evans is working on his but he has no ETA. Hopfully he will have it my Jan-Feb of 2012 before autocross starts back up.
Old 06-22-2011, 09:33 AM
JNS2001's Avatar
^Full Blown makes a lead to connect the Sprint 500 to the stock ECU for AP1s. OBD-2 compatibility . I'm currently looking into this option.
Old 06-23-2011, 07:16 AM
Banned
Kyushin's Avatar
Ya... Kpro would be the undisputed champion if they got off their asses and made wideband feedback a supported option.
Old 06-23-2011, 10:24 AM
josh7owens's Avatar
No Emissions testing in Kentucky
Old 06-27-2011, 05:42 AM
panapower's Avatar
yep, no emissions test down here either!
Quick Reply: Haltech's Honda S2000/AP1 PRO Plug-In ECU
