Honda OEM O2 sensor reliable wideband?
Old 02-18-2011, 10:56 AM
SlowTeg's Avatar
Default Honda OEM O2 sensor reliable wideband?
Well, just like the topic says.. I've seriously been considering a flashpro, and I wanted to know if the OEM '06+ honda sensors could be used to measure a/f ratio for tuning. I recall reading in some threads that it's quite accurate, but anyone like gernby or anyone else care to chime in? If I don't have to buy a separate wideband, it's obviously preferable in the sense I don't have to spend more money. I can just datalog off the stock sensor and do a/f tuning that way.
Also, for running a test pipe with the flashpro, it's as simple as selecting a checkbox to disable the secondary o2 sensor codes correct?
Old 02-18-2011, 11:40 AM
Former Sponsor
Gernby's Avatar
I am very impressed with the OEM wideband. It may not be 100% in agreement with better widebands, but it's definitely good enough to tune with. Mine seems to read about 0.2 richer than it should, which seems totally acceptable.
Old 02-19-2011, 06:06 AM
SlowTeg's Avatar
Thanks for that info gernby. I think I asked it in another thread, and it was you who responded with a similar response. I have a test pipe and hondata on the way, so it looks like I'll give the test pipe and reflash a back to back test compared to a stock car as well.
I see you provided your software dyno info, and thanks for sharing that with the community as well! I'll have to read through a bunch of threads to get fully up to speed with the hondata, but it seems very similar to the older hondata I used to have where you had to repeatedly burn a new eeprom for a new tune (bigtime pita).
Broman_The_Swede
07-17-2016 11:58 PM
fallen612
04-21-2011 07:13 PM
pemex70
10-04-2007 09:40 AM
Dolemike
12-20-2004 11:16 AM
Quick Reply: Honda OEM O2 sensor reliable wideband?
