ScienceofSpeed Connector Kit for Hondata K-Pro 4
Former Sponsor
We love the new Hondata K-Pro 4. However, we don't love the analog and digital cables that are supplied. They easily slip off the K-Pro 4 board if not tightly secured to the ECU and removal of the ECU requires opening the cover to disconnect the cables.
ScienceofSpeed is now supplying two sets of automotive grade sealed ten position electrical terminals for Hondata K-Pro 4. We include instructions on terminating the Hondata supplied cables to these connectors, and a pin out for each accessory. This allows the ECU to be removed from the vehicle by simply disconnecting the two sets of connectors and allows the digital / analog cables to be secured to the ECU to prevent the cables from disconnecting.
We're supplying this kit at no charge for customers that purchase the K-Pro 4 from ScienceofSpeed (enpp-2881).
more info:
http://www.scienceofspeed.com/produc...Hondata/K-Pro/
more info:
Former Sponsor
Just ran across this. Great idea and product. It'd been nice for Hondata to spend the couple extra bucks to include this, but it's awesome you guys are going above and beyond for your customers in this regard in light of their shortfall.
I was disappointed to receive this and realize it was just 4 connectors and some pins. Based on the pictures (which no longer work) I thought I was getting a premade cable that plugged into the Kpro board along with 2 connectors for my sensors. I guess it was my fault for not asking , i didnt get any instructions either
I bought these on Amazon and made my own. It turned out really nice. Just make sure you have the right crimping tool. I used plastic ties as stops to help keep the board plug from pulling out.
http://www.amazon.com/gp/product/B00...ilpage_o01_s00
The upper harness is the digital in/outputs and the lower is for all the analog.
Check the Hondata help section for pinout https://www.hondata.com/help/kmanager/analog_wiring.htm
