1/4 times with turbo
Old 12-07-2014, 06:25 PM
  #41
hybrdthry911's Avatar
Car made 390 at 10psi, he's running 14.5psi so quite a bit more than 390. I went 11.9@120.9 at 390whp(365whp on a difference mustang dyno) in my NSX, but the gearing helps a little.
  #42
5thgen's Avatar
Originally Posted by KaNgArOo
Thats a crazy fast trap speed for 390whp.! What dyno was it on?
It was not at 10psi for the whole run. It was basically around 8-10 for 1st and 2nd gear, but it was on a dynojet.
In gears 3-5 my max pressure was around 13.5-14.5.
edit: I'm too slow jr.
Old 12-09-2014, 06:25 PM
  #43
KaNgArOo's Avatar
So thats probably around 430whp. Thats still a fast trap for 14psi.
Old 12-10-2014, 07:16 AM
  #44
turbodreamz22's Avatar
I had a 500whp evo and I trapped st 126mph. So 400whp+ I say should be 118mph+
Old 05-07-2018, 05:51 AM
  #45
Mijae007's Avatar
Made one pass yesterday at eibach before getting kicked off for not having a helmet/jacket. Bogged pretty bad off the line. Pretty sure i could make much better time with more runs. Trap speed was a bit lower than i expected for 515whp.
im on the right
Old 05-07-2018, 06:45 AM
  #46
Chuck S's Avatar
Received 1,132 Likes on 995 Posts
Of course you're on the right! No one would post a S2000 15 second time if it was their's. Probably not even a NA car.
What car was on your left?
-- Chuck
Old 05-07-2018, 07:57 AM
  #47
Mijae007's Avatar
i dont remember, a 2012ish civic si?
Old 05-07-2018, 12:17 PM
  #48
hatrickstu's Avatar
im on the right
500whp should be damn close to 130mph, if not over. I went 126 on my ONLY pass ever at about 450whp. That was with a soft 2.2 60'.
Old 05-07-2018, 12:54 PM
  #49
Mijae007's Avatar
Yea i'm a bit confused as to why my trap speed was so low. I too started with a soft launch and after the bog in 1st it felt pretty good all the way to the end. I did lift off the throttle just slightly in 3rd and 4th since it started to get squirrely. Maybe its my tires spinning some?
I could probably gain another 5mph with a better start and tires but hard to imagine gaining another 15mph...
Old 05-07-2018, 05:03 PM
  #50
MARK AUS S2K's Avatar
Who here is running the stock 4.1 Final Drive? Is this best for faster acceleration?
Quick Reply: 1/4 times with turbo
