High enough for oil return?
Old 01-15-2013, 02:18 PM
tx2K's Avatar
Default High enough for oil return?
So, I've been going back and forth trying to decide how I wanted to do the oil return and I just decided to go with the pan seeing how many people do that without problems. But, Ive only seen a couple of pictures. With that being said, I came across a pan for sale that already has a fitting welded on and I would like to know from you guys that have return setup to the pan if its high enough? Please help me out so I can decide whether to buy or not.
Old 01-15-2013, 03:23 PM
bobbyrandolph440's Avatar
Y not timeing cover super easy without any problems at all
Sent from my DROID RAZR using Tapatalk 2
Old 01-15-2013, 03:25 PM
But no that looks way low on that pan here is guy that done cover
https://www.s2ki.com/s2000/index.php...rbo-Oil-Return
Old 01-15-2013, 05:39 PM
tx2K's Avatar
Thanks, I have looked into both. I just figured it would be easier and a lot less work to do the pan if it works well for others. I may end up paying someone to do the cover depending on the cost. Just thought I would ask about that pan since I came across it though.
Old 01-15-2013, 06:13 PM
riceball777's Avatar
it will be fine
Old 01-15-2013, 09:29 PM
Johnson86's Avatar
It's fine. Mine is in the same location and I'm having no problems at all.
Old 01-16-2013, 10:39 AM
Banned
Kyushin's Avatar
Just hit up the Bawss, he sells the covers with a fitting welded in and the quality is amazing!
Old 01-16-2013, 12:06 PM
Deception's Avatar
do timing cover or girdle
Old 01-16-2013, 05:38 PM
choleaoum's Avatar
How hard is it to swap out the timing cover?
Old 01-16-2013, 06:39 PM
hybridsol's Avatar
+100
I did the valve cover swap. Really easy, except for the crank bolt which can be, well, cranky. Since I had it off before with the kpro swap, it wasn't too bad. Need the tool for the balancer ($25) to hold it still.
And remember, the belt tension pulley is REVERSE threaded- don’t be a bonehead like me and snap it off!
Steps are:
  • Oil pan
  • Belt
  • Pulley
  • Balancer
  • Cover bolts
Not bad at all. 2Hrs including cleaning oil pan gasket material.
And Bawss is *super* guy to deal with!
Quick Reply: High enough for oil return?
