AEM Infinity
#41
Car just would not run, so frustrating. Ended up being that the plug to the map sensor didn't have 5v source going to it. I had to bridge from the TPS to the map for 5v signal. After dealing with AEM tech it seems like they knew it was an issue and didn't do anything to make the situation better after hours of diagnostics at my expense of time and money.
#42
#43
Very likely a one-off. neeman77 is doing some quality hand-waving while attempting to explain AEM knew it was a problem and didn't do anything about it. Not doubting he had a bad harness, just doubt it is a general problem with the AEM pnp harness. My AEM pnp harness works fine with my Infinity.
#44
#45
Of all the plug and play Aem harnesses with infinity I've installed/tuned there haven't been any major problems all easy install and tuning including the s2000, I'm sure you'll be ok.
haha the s2000 app does have a lot of ecu/wiring to mount but you can get it all to fit behind the plastic kick panel without to much fuss.
#46
Just explaining my experiences and the impression I got from AEM tech that this was not a one off issue. I have nothing to gain or lose providing this info. I am sure the few that had issues were early harnesses as I had one of the first available, I actually intended to give SOS my support rather than bring down AEM with my initial post.
THMotorsports
12-12-2015 02:45 PM
