Battery Relocation and Fuse Box Relocation
Ok, Along with the Methanol Injection Kit I will be removing my battery to the trunk, and I will also be putting my Fusebox in the location of where the Washer Tank is (in the fender), the search is to little avail, does anyone have any good write ups on these to re-locations?
I had to cut quite a few, extend some, it was a day project when it was all said and done. Not that hard, but a bit time consuming. I also did the AC relocation lines as well why I was at it.
anyone ever relocate the fuse box in place of the passenger airbag? This would leave it accessible to switch out fuses simply by removing the airbag cover. I think I might try this.
i would personally relocated the fuse box under the passenger area, above the footwell. You then don't lose the airbag and don't need to remove the fender to access the fuses.
