Best place to get exhaust manifold studs
Can anyone tell me where the best place to get ARP studs with HEX nuts for the turbo manifold is? It was suggested that I not use the new OEM nuts and studs because they are weaker and come loose so now I need to get these delivered this week so I can hopefully do my install this coming weekend.
Here's where I got mine:
DMP
I use the 1.75" ones as the 1.5" were not long enough when using washers (with my full-race manifold)
I would also highly suggest using Nord-Lock washers to prevent nuts from backing off.
I've been through several setups and what has worked best for me:
1.75" ARP exhaust studs, Nord-Lock washers, new OEM nuts
Hope that helps
Scott-
DMP
Hope that helps
Scott-
Ok, so will the OEM nuts thread onto the ARP studs? Is there a kit or do I just need to get individual parts? Redboost, OEM studs is what I was told should be replaced. I just figured Id get a kit that had nuts as well so I didnt have to make a trip to the local stealership.
the website posted above makes it nice because thats just for the stud so you dont have to waste money on the nut/washer that comes in the whole kit.
