Boosting on stock 360cc injectors
I will be running a smaller pulley (4'') on my Comptech kit with stock injectors. I have spoke with junky in another thread that I will be using the black box and getting a full dyno tune with it.
Junky question... will I be safe with that? I don't wanna risk my motor
Are you referring to the ACM unit when you say "black box"? If so that's what I'll be using, it's the piggy back that comes with CT-E's SC. Apparently there's a way to make adjustments using CT-E's ACM. I'd like to know how everything turns out for you. I'll keep you guys posted once I get my pulley upgrade as well.
I forget, are you running an F20 or F22?
I wonder if a e-manage would help when pushing the limit with the rrfpr??
My guess is adding a little injector duty when fuel adjustment are near max on the rrfpr should do it ?? And be carb legal
A local friend/member tried that combo and it didn't work reliably. He was experiencing problems anytime he tried to add more injector duty with the added pressure. Apparently the combination didn't work well with stock injectors, they just couldn't handle the combination of a high rising rate pressure with more duty. Now, when I was running 18psi/450whp with my Supercharger I was using the Emanage, but with ID 1000cc injectors. There is little point in sticking with stock injectors if your going to move into the fuss of a programmable ECU. Its the piggy back ecu that makes it technically smog compliant, not the injector size. So at 450whp I was still passing smog, because I still retained the oem ecu for obd2.
I didn't get much luck with the emanage and the Id 1000. I remember getting a base map from somebody here for it ( cant remember exactly who ) and some help from you a few years back.
My tuner didn't want to tune 1000 with the setting at 660 like he should have. So we couldn't get the ltft and stft to stabilize. So we forced the ecu to constant open loop and as you know it didn't like it.
Ended up with an haltech.
Back to topic
Back to topic
Back to topic
Back to topic
I have a Vortech V2 on my AP1 F20 with a 4" pulley. Might be 4.25". It has the supplied 5th injector installed and seems to run rich. Is it safe to stay with that 5th injector or should I rather upgrade the stock injectors and remove the 5th altogether?
