Boosting on stock 360cc injectors
#21
What is your afr reading would be my first question? Did you buy the kit used?
#23
Wow, haven't heard of someone running this kit in a long time, I forgot about the 5th injector system, but think it was just for the ap2? Maybe this is why your running too rich. I never seen one up close and was always curious about how VT has the 5th injector managed.
am I safe with the 5th even if I go from 8 to 10 psi?
#25
#26
you're right. Its the AP2 kit. I bought it used. It came with my car actually. I can smell fuel on the dip stick. Apparently it was tuned safe but unfortunately I do not know what the AFR is yet as I need to get a new belt on before going to retune and get the accurate readings. I also need an AFR gauge asap.
#27
Smelling fuel on the dipstick is not good, it means your getting a substantial amount of fuel in your oil. The 5th injector system was meant for the higher fuel demands of the ap2 engine which you are not running. I would stop driving the car asap and drain the oil and hope you haven't already done damage to the engine. You should pull all your plugs and send us pics. You do not want to exceed 7-8psi without the means to retard/tune timing. Your on a stage 1 level kit. I strongly suggest you invest in a wideband for the car if you want to reliably run your current set up over anything the tuner is your to tell you/do for you. You have to run the right afr on this kit or your engine could be short lived. Does the rrfpr that came on this kit have an external adjustment post on it? Or is it one of the crappy pre loaded internal puck style non adjustable rrfpr?
And the FPR is the stock Vortech one from what I can tell.
What is wideband by the way - the wideband AFR gauge?
#28
When I smelt the dipstick the other day the smell of fuel wasn't really there or as strong as before. I can send pics of my old plugs before going one step colder. They were the stock plugs. I upgraded to BKR8EIX. In light of what you said, can I remove the 5th injector and run the setup as is with 8 psi, get a retune and that's that?
#29
If you cant adjust your rrfpr then there is nothing to tune. comptech had an adjustable rrfpr, vortech has one but wasn't offered in their kits. The only way to know if your running in the ballpark of being safe is if you either pay a tuner to run a tail pipe sniffer wile you do a run on the dyno (expensive and not that accurate) or invest in the wideband afr gauge (less then $200 and check it yourself on the street which is a must have investment for being boosted for troubleshooting now and the future. Depending on what your afr is, will determine your next course of action. That's where your at right now. I don't like it when I hear your situation and then hear about smelling fuel in the oil, ive lost motors from fuel wash and bad tuners in the past. It can happen quickly if things are not right.
You got me worried now about the "fuel wash" thing... I don't DD my car by the way. Apparently its normal for you to smell some gasoline on the dipstick in all cars. Mine isn't a massive smell like there's only fuel in there. Come to think of it my Corolla also exhibits that and the car is very slightly modded with no ECU tuning and no boost of course. Sounds like you had some really worst case scenarios there
#30
If you have the rrfpr and u dont wanna swap back on stock fpr which I imagine is pretty easy ain't it? At least bring the pressure down, your stft an ltft should be able to help out and keep ya safe. Not sure what regulates the fifth injector but if it's not the ecu and in NA it's deftly not needed. I guess if it was boost activated then it could stay. ... Eh No real experience with this setup, but for NA it's not needed.
Good luck, don't rush it. Perfection takes time.
look for progression then perfection.
