churches dyna pack vs raceline dyno jet. My results
Old 11-21-2012, 05:24 PM
  #21
spdracerut's Avatar
Originally Posted by timg
This is an old, but good read. Dynojets can be just as inaccurate as any other dyno. All dynos rely on trained personnel and up-to-date calibration.
http://www.turbomagazine.com/tech/03...h/viewall.html
With that said, there is a good reason why OEMs use load bearing dynos like Superflow, Dynapack, Mustang, Rototest, and Mainline Dynolog.
Tim
Another good read:
http://www.motoiq.com/magazine_artic...lieve-one.aspx
Old 11-23-2012, 08:26 AM
  #22
Ben @ Carolina Dyno's Avatar
I would let them have a go at tuning it. Just by looking at the graph it is obvious something is wrong. You're graph should be very smooth especially with the smoothing on 5. It is also possible that Churches was using your wideband to tune with which could be wrong. When we tune we use Innovate widebands because we have found them to be the most accurate. I have found many AEM gauges reading very far off in customers cars before. I've even replaced my own sensors and re-calibrated just to be sure. In our experience AEM is the least reliable of the wideband controllers.
It's really no surprise at all about the power difference though. We use a Superflow and it would read even lower than the Dynojet.
Old 11-23-2012, 09:11 AM
  #23
Banned
Kyushin's Avatar
Not surprised here... my completely stock ctsc at the time, read 345 on his dyno
Old 11-23-2012, 10:28 PM
  #24
liquid_helix136's Avatar
From what I've gathered, the closer the o2 sensor is to the engine, the more accurate of a reading your going to get. Having an end of the pipe sniffer compared to an in-line sniffer, I'm gonna put my money on the latter being more accurate, all else equal. To make things even more complicated, some people consider just one wideband to be insufficient as each cylinder is going to have slightly different AFRs, the wideband 99% of us have just read a mixture of all 4 cylinders, so as far as we know, 2 cylinders could be stoich, one could be super rich and the last dangerously lean, and our o2 sensors would be reading 14.7.
If your truly worried about it, I would just pick up a new wideband, pop it in and see what it says. If it reads 11s, you'll have peace of mind, a new wideband and you can sell your perfectly working old sensor.
Old 11-24-2012, 05:06 AM
  #25
It's just as likely (actually much more likely) that if there is a problem with his wideband it's the controller/gauge and not the actual sensor.
Old 11-24-2012, 10:11 AM
  #26
Thunder-rush's Avatar
I'm with Ben here. You should try to tune on that dynojet. Your graphs on both dynos look choppy and thats a sign of a not that good tune. The curve should be smooth..Especially with smoothing already added to the graph.
Venomous S
06-18-2006 07:26 AM
24s2k7
12-31-2005 07:49 AM
Chiung
07-13-2004 03:49 AM
Wesmaster
08-30-2001 10:43 PM
Quick Reply: churches dyna pack vs raceline dyno jet. My results
