Compressor surge under load?
I ran my 1200 blower/3.2" pulley with the standard Comptech set up 5.45 crank, and aftercooler seeing 17-19psi depending on ambient temps. Ran the stock diverter valve off the old 3/4" aftercooler nipple that used to be for the OEM air injection, and then a simple 25mm pnp Turbo smart BOV at the normal location. Never had belt slip and never had any kinds of issues being reported here with compressor surge. My 2 25mm BOV were also plenty able to evac with no flutter and operated under the standard light 1-3lb opening, to allow max boost at 0 vac throttle for max performance. Vtec set at 3500rpms and comes in at 0 vac/30ish% throttle opening. Rock solid consistency and got all available performance out of the blower. Only thing I can think of why some guys are having these out of the norm issues, is because they have added variables and complications to their set ups, deciding to depart from the standard kit layout which proved so reliable.
its just colder air and a big blower with air to water my iat's where almost double in some instances especially after stopping the car for 20 minutes in 100f weather those high iat's made it a dog now the car is crisp as a cold start.
Here are some pics of my setup . I was able to stop the surge with lowering vtec using cast 90 degree elbows welded to the 3 inch pipe this gave me great flow along with a very efficient intercooler that and dual staggered bov's and poof surge gone i did have to tune it myself and study thermodynamics. like i said cold air + less compressive charge with restriction at the valves = surge
Ok so i am running a novi 1200 with a 6.75 crank pulley and 4'' blower pulley sos tb t1r 70mm rx comptech 4-1 header 3'' intercooler pipe 4.5'' treadstone 860hp core 2 50mm tial Q50 bov's the hot side is set at 6psi the cold 1,5 vetc above 38% throttle 3300 rpm. I modded my oil pump to make sure i have the pressure at that rpm. The problem as stated is this blower is too large for the size of our motors [I run an ap2 drivetrain] so on the low cam there isn't enough lift and duration to allow that air to be released so it starts backing up and when it hits a resonance is will back up the intercooler to the compressor causing great strain on the blower causing the belt too try and slip. So the way i went about it was allowing as much air out as possible and as much in as possible and getting on the high cam is paramount I would think you want as much overlap as possible. This is what i found swapping to air to air from air water cold air = less compression and your surge line goes up i was running 130-140 f cruising and up to 160 f in the Texas summers with my air to air 117f idle is as high as i have seen and in boost i am ambient temp. also find if I run one baffle it help quell the light blurb er i still get near boost tip in under light throttle. Would need more info on your setup to say more
p.s. i am making 16psi at 8500rpm
when i was air water i had some surge up high and on throttle chop with a godzilla bov and vm 25mm bov and it wasn't enough to keep the novi 1000 happy so i went full retard when i did this setup if i was running your pulleys i would be seeing 20-22 psi at 8500 rpm
Another interesting mix to throw into the equation. So I introduced a boost leak by removing the plug in the air injection nipple on the aftercooler. The fluttering of boost was reduced, and it still made the same psi at 5000rpms. That goes to show that the blower is producing more air than the engine is able to consume.
Originally Posted by rmerchant3' timestamp='1465865543' post='23992550
[quote name='s2k manic' timestamp='1465854536' post='23992371']
[/quote]
I know others have had success with this blower, but my setup is not far off from anyone else who has used it. The compressor map shows that the s2000 engine is right on the surge line. I have ran a 3.2 pulley and it still fluctuates. I believe what is overlooked is the amount of CFM that this thing moves. I'm not vast with turbos, but I believe the 1200 has a higher cfm rating at lower psi numbers as compared to a similar sized turbo.
The only great departure I have added is the Tial QRJ, and that should not have affected it unless it was leaking...which after numerous test I have found that it is not. I'm still completely open to ideas.
Originally Posted by s2000Junky' timestamp='1465881141' post='23992690
[quote name='rmerchant3' timestamp='1465865543' post='23992550']
[/quote]
[/quote]
The little old NV1000 we ran on our old Comptech kits for the last 10 years was 900cfm. The 1200 upgrade is rated at 1150cfm offered later when the 1220 series came out to replace the NV1000 just for fyi and any turbo cfm cross reference.
I would bet some small cookies that your chosen BOV and spring/adjustment opening/closing timing may not be calibrated appropriately, influencing the symptoms experienced. That is a Turbo BOV which do have different operating parameters over a centrifugal sc valve. I would get your hands on a original Bosch diverter valve, and run that inline and make sure your Tial is timed in sync with the Bosch unit, only then would I feel comfortable moving on to troubleshooting in a different area. You can simply do this by verifying the valves are venting at idle as they are blowing on your hand, and then close at same time when you turn the TB by hand to induce throttle. Making sure the BOV is holding to redline at max boost is important to, but shouldn't influence your problem I wouldn't think, cant do that under the hood anyway.
Another thing to check, make sure air cleaner or related intake piping are not collapsing or creating obstruction under higher pressures.
Originally Posted by rmerchant3' timestamp='1465907961' post='23992861
[quote name='s2000Junky' timestamp='1465881141' post='23992690']
[/quote]
[/quote]
[/quote]
The QRJ was developed for superchargers. I have the -1.5psi spring in it. Even still, this was my first point of diagnostics. I capped off the Tial and ran my old Bosch off the air injection nipple. I knew this was asking a lot from the Bosch, but it didn't change the fluctuation at all. I then went back to just the Tial and mounted a gopro under the hood to watch the valve while driving. It is completely sealing under full throttle and seems to be venting appropriately according to vacuum/load. My fluctuation in boost occurs at anything above 60% throttle, including WOT.
I have also tried three different air filters. One of them was a shorty style to get rid of the supplied SOS tube. Fluctuations stay the same with any air filter.
This is the video of the QRJ in action. 1:50 and 3:35 are good spots You can actually hear the flutter right before I let off. Especially 3:35.
https://youtu.be/qR4qwNdc4lE
