First turbo question
so I have searched and found a few threads with generic parts list of everything needed. I'm going to list everything I have, would like to know if I'm missing anything. Almost everything is already on the car but being my first turbo build want some conformation.
List:
Comp turbo t3 .63 a/r
Pfab log manifold
dump tube
intercooler and piping
5 bolt 2.5" Downpipe
aem ems
modifry temp fix
ID1000
walboro 255
38mm turbosmart waste gate
generic bov
mac boost solenoid
hondata 4 bar map sensor
Tapped oil pan
oil filter relocation kit
Thanks in advance for any responses.
List:
Pfab log manifold
dump tube
aem ems
modifry temp fix
ID1000
walboro 255
generic bov
mac boost solenoid
Tapped oil pan
Haven't grabbed plugs because I'm unsure what to run. I was running 4554 ngk which is a cooper plug one lower. That was when I was running nitrous. Not sure what plug to switch too
Just some stuff you need to add.
spark plug, oil pressure gauge, boost gauge, wideband, oil feed/return with fitting and restrictor, fuel pump with wiring kit, clutch this is just some stuff on top of my head.
for now plugs and clutch still undecided. Clutch I'm leaning towards SOS 400
I'm on a competition stage 4. it's not bad if you don't mind the grabby clutch. no clutch buzz.
https://www.s2ki.com/forums/forced-i...-sale-1164911/
1 step colder should be sufficient. Lately I have seen it go by actual #'s your hitting. So one step between 100-150 added hp, n then 2 steps colder for 150-300. Those numbers should be in the ball park but don't quote me on it. Just sharing what I have read.
