NEED HELP with my greddy turbo kit
Old 09-17-2013, 03:46 PM
Donadio91's Avatar
Default NEED HELP with my greddy turbo kit
Hey guys,
I need some help with my greddy turbo kit(used). Before i begin you should know that it didnt come with the emanage so i had to buy a new one and get a used PnP harness which i believe was on an ap2(do i need to change anything for the conversion to an ap1 harness besides the throttle wire?). So i have just finished installing the kit on my ap1 and once the rpms get below 1,000 at idle i get an error on the emanage that reads [low vtec input signal under 1,000 rpms]. I get no vtec and the rpms are limited to 7k. Any help would be awesome.
Old 09-18-2013, 09:55 AM
Donadio91's Avatar
bump!
Old 09-19-2013, 06:00 AM
Donadio91's Avatar
I know i have heard of others having the same issues, do you think bad turbo maybe?
Old 09-19-2013, 06:12 PM
S2KCHRIS305's Avatar
im not exactly sure what it is but ive seen people with this problem, look more into the greddy turbo thread youll find it in there for sure, i think i remember reading it had to do something with the emanage but im not sure
Old 09-20-2013, 04:23 AM
Donadio91's Avatar
I looked into a bunch of threads about this but no one says how they fixed the issue
Old 09-20-2013, 06:16 AM
Donadio91's Avatar
By the way how did you get so much hp out of your greddy kit?
Old 09-20-2013, 09:51 AM
I guess its cause of my setup. im running e85, with ID1000s, Stock exhaust with 70mm test pipe, boosting 13.5 psi. I wanna get a ram horn manifold and convert to external wastegate , also add full 3 inch exhaust and it should put me into the 400s.
Old 09-20-2013, 10:03 AM
Donadio91's Avatar
Originally Posted by Donadio91' timestamp='1379686599' post='22788185
[quote name='S2KCHRIS305' timestamp='1379643164' post='22787592']
[/quote]
ahhh thats make more sense,thats still really high numbers for a stock exhaust. i thought you were on a stock greddy kit, are you still on the t518z? If so i didnt know it could make that much boost efficiently and i thought that the e-manage wont let you turn the boost up that much. You must have a good tuner.
Old 09-24-2013, 04:11 AM
Donadio91's Avatar
Just in case anyone else is running into the same issue, the answer was the jumper settings.
Donadio91
09-19-2013 05:47 AM
s2kdrez
04-16-2011 01:03 PM
Rashido
02-01-2010 01:32 AM
seoul2k
01-19-2010 02:44 PM
Quick Reply: NEED HELP with my greddy turbo kit
