King Tut's PTUNING Turbo Kit Build
Originally Posted by riceball777
Nope. I really wish it did. The tunning kit mounts the turbo super low which is why you must use there custom mount. This kit is perfect in every way with the exception of the motor mount. Even with the yellow insert which is the softest one the vibrations and the Loud cabin she to their mount really gets old and tireing for a daily driver. My brother has this kit so I work and drive his car a lot so this is where my opinion comes from.
Damn, I thought it might be a long shot. I agree the mount is the only real downside to the kit. I don't know why but my kit never vibrated excessively, and yet I know another car with the kit was a lot worse than mine.
Mine came with AN lines for the coolant lines and heat shielding to go over them. Then they switch to rubber hoses to connect to the OEM coolant locations. I will try to get good photos.
Day 2 Update:
For the first time I am confident that the TiAl housing is properly seated on the manifold. I had a buddy come over tonight to help hold the turbo while I made sure it was lined up and tightened the V band clamp. I didn't get time to try and get the downpipe and dumptube connected again, but with the turbo not installed properly I still managed to get everything lined up, so I am optimistic. I did finish up the cooling fan and wiring along with the intercooler brackets and mounting the oil scavenging pump. Day 2 photos:
PTUNING Brackets, SPAL Radiator Fan, and Wiring:
PTUNING Intercooler Brackets and Oil Scavenging Pump:
Couple questions for you..
With the V band flanges I guess backing out of bolts isn't a concern at all? I get it's more difficult to line things up, but it's a shame more kits don't use v band flanges..
Also, you're a brave man! You're going to rock the OEM radiator? Good luck, hopefully it'll do the trick. Are you still running A/C in your car as well?
