KraftWerks C38 Supercharger Kit FAQ Thread
#162
Get a double sided stud... screw the stud all the way down and then put 2 nuts on the other end .. I would not put another bolt in .. I've had them come out with locktite .. and had it break in the block ..
#164
I used the Dual port bov from turbosmart with the softer spring from the plumb back model. Worked well and was a direct swap from the billet KW piece.
#165
My KW BOV did that too initially. But after a while it stopped and has been smooth ever since. Maybe it just needs to be broken in.
#166
Originally Posted by schhim' timestamp='1476815329' post='24086906
Anyone using the 25mm Turbosmart BOV? I think I'm hearing some surging going back into the blower when I let off and shift at high boost. If you are, which spring are you using? Thanks!
#167
Originally Posted by Memo6453' timestamp='1476842711' post='24087249
[quote name='schhim' timestamp='1476815329' post='24086906']
[/quote]
I used the Dual port in both applications. The VTA sounds cool for about 10 mins, and then the hairdryer sound got annoying. Since s/c is belt driven, its constantly purging air when in gear and off the throttle. So i ended up going back to the block off plate. Regardless, its a nice piece than the KW billet valve. Also, i ordered the Green spring TS-0203-3003 to use for the s/c. This was recommended by the TurboSmart rep i spoke with. you can find them on Amazon, or give Ryan (Moddiction) a PM.
#168
I was able to get bolt size if anyone needs it in the future.
M8x1.25x40mm
#169
tune for kraftwerks kit
I recently bought a new kit but it didn't include a base map. I've tried contacting kraftwerks for 2 weeks with no response. I was wondering if anyone has the base tune for the aem v2 still sitting around they could send me or lead me to where I can get it? Thanks in advance.
#170
There should several maps in your C: drive. Assuming you downloaded the AEM tuning software.
AEM Performance Electronics Support - Software Downloads | AEM
-- Chuck
-- Chuck
