Low fuel pressure?
Low fuel pressure?
Hey guys, I just recently purchased a fuel pressure gauge, a 340 lph fuel pump,and an AEM fuel pressure regulator. Before these parts were purchased, I had a Walboro 255. I'm currently running Deastcwerks 1000 cc injectors. My first issue is that when I turn my car off, the fuel pressure instantly drops to zero with my AEM FPR. I switched it back to the stock FPR, and it holds at 29 psi after i turn the engine off. Is this normal for an AEM APR, and is 29 psi normal pressure for the stock FPR? The next problem is, my fuel pressure on the stock regulator is at 40 psi with vacuum line disconnected, with the Vacuum line connected, it's at 35 psi. Isn't this very low? I thought the stock fuel pressure was suppose to be at 50 psi unconnected, and 40 psi connected. My fuel pump is brand new, and i did not find any leaks around my injectors or lines. For the fuel pump install, I used the stock clamps to connect the fuel line to the fuel pump.
I had 45psi base pressure on my OEM regulator and used the same on the AEM. My tuner wanted the vacuum line connected and that gave around 60psi at 14psi boost.
Don´t know about the drop after you turn it off, never tested it on this car but know that a few race pumps come without the one way valve that OEM pumps have and then it would be normal. Maybe we have that valve in the FPR instead?
Either way you don´t need it if you can run the pump on ignition a few sec before cranking, that will help you reach the right pressure before start.
The aem fpr won't hold fuel pressure once the car is off. Due to the nature of the design it's essentially an adjustable bleed type system. Mine does the same. Nothing to be worried about. Your stock fuel pressure does seem low though
Thanks. My fuel pressure actually dropped down to 32 psi today, which I blame on 113 degree weather. I could turn up my fuel pressure with the AEM, but I feel like that would just be a bandage hiding the real issue. I have a completely new fuel system, just don't get why it would be that low unless I have a leak somewhere.
That's the only thing it could be. I'm gonna replace it this weekend and use the screw clamps provided instead. I will provide updates if this fixes the issue.
I just replaced the in tank fuel line, and used different clamps. My fuel pressure is still at 35 psi at idle. Maybe my 1000 cc injectors are draining too much fuel too fast from my fuel rail? Whatever it is, i'm just going to put the AEM FPR back in, and turn the fuel pressure to 40 psi.
