pfab - gtx3076r - stock block - evans tuned
finally got the car tuned a few weeks ago
pretty happy with the results so i figured i would post them up
car made 510whp 325ftlbs on a 60degree day on pump gas with 15psi
modifications
stock block
hondata flashpro with boost by gear (installed but not being used on pump gas)
pfab garrett vband topmount manifold
apr manifold studs
pfab 3in down pipe, custom wastegate dump
pfab stage 2 intercooler
gtx3076r .82 tial housing
tial q 50mm bov
precision 46mm wastegate
id1000 injectors
inlinepro fuel return system
fullblown 340lph pump
sos 4 bar map sensor
CC 6 puck clutch
sp boost actuated exhaust cutout with stock exhaust
modifications
stock block
apr manifold studs
tial q 50mm bov
id1000 injectors
CC 6 puck clutch
here is a pic i saved off awhile ago and my setup is very similar just a little further back, didnt ever take any pics of mine
(sorry to whose ever car this is, hopefully you dont mind me posting it up again)
When you say not using Boost by gear do you mean your on WG spring or just using ECU to control boost but not by gear?
Nice numbers! didnt think Jeff was comfortable tuning pass 13psi on stock block with no HG!
