Project Instant Torque...Dynos and info inside!
#51
I wanted one of these blowers sooo bad when I first planned to go FI. This is a great build and the price is right!
I didn't know salvage title S2K's could be had for so little. Might have to find myself another one.
#52
it is amazing what he has accomplished with that tiny blower and a bad ass stroker motor. Now, I really want to see a mp112 or similar sized blower. possibly a tvs1320. you get the idea, something that can move a nice amount of air and deliver 450whp. that would be the jam.
#53
Why not run the big meth injection stage starting at 4500rpm to get the bulk of your old tune/mid range back? Leave the small/first stage as is. So you only lose roughly 1500rpms down low of what you had, which is a fine trade off to get that power moved to up top where you gained currently. I dont see any reason why you had to sacrifice current performance from 3500-6500 rpm.
It all comes down to this, this Meth controller is a PITA disappointment, particularly for this type of FI. I friggin wish it could read throttle % so bad then you wouldnt have to worry about the part throttle meth inj cause it wont be at all. I want it setup so at 80% or more throttle the meth inj starts. Regardless if Im at 3krpm or 8krpm or anywhere between.
So stage 1 at 3k 80% + throttle and stage 2 at well say 5k. I cant set it up like that right now tho.
But really honestly when your actually racing around reving to redline then shifting the rpms dont drop below 6k. So technically I made gains where it "counts". But hey trust me Id like to have not lost that midrange as well, but for now I have to sacrifice it for driveability.
#54
#56
MY S2K VS AUDI S6
3rd-5th pull damn dual clutch transmissions haha he dug in a bit everytime I shifted. Were gonna rematch soon front a 1st roll
#57
Had to use my 50amp charger to jump start my s2k this morning. Jeff Evans said about the ems's being sensitive to voltage/amp output. Although the car was cranking over and over you could tell it wasnt 100% cause of the cold battery. Im gonna have to get a bigger battery I think or start trickle charging the battery a few times a week in the cold weather.
The excess draw from the gauges, fans, and water pump on the aftercooler/heat exchanger are probably putting to much of a strain on the battery in the cold weather. Normal oem size battery less then 1.5 yrs old right now.
Ill be parking it for the winter around December or before the first good snow fall. PA winters are to salty for the s2ks imo
#58
I rock a group 34/78 ootima yellow top mounted in the rear. However I still leave it on a optima battery tender whenever I park the car. Battery will go dead after a few weeks otherwise. This is my second one. First yellow top group 34/78 lasted 7 years.
#59
Been awile gentlemen, quick update. Jon Bond Performance is currently rebuilding my blower and porting it even further ( to the absolute max ) as well as adding new ceramic coated rotors. Im told if I get a dyno data from before and after rebuild and porting with no other changes Jon Bond will provide me a refund on the port job ( $299 ). He has flow bench data but no real world back to back comparisons.
Also e85 pumps finally were installed in my home town so Im going to be going that route this summer as well. 425-450hp?!? Well see!
#60
otbs2k
Member S2000 Classifieds and For Sale
30
12-07-2008 10:25 PM
