Riceball777 f24 stroker turbo motor flex fuel build
Old 03-22-2017, 05:31 PM
  #91
nguyen365's Avatar
Originally Posted by riceball777
I finally got my rpf1s on. The inside of the 17x11.5+63 actually hit the inside very slightly. I could have probably gotten away with a 3mm spacer. But instead I had asm fender flares put on and had the rear oem fender cut and welded. I'm now running a 15mm spacer making the rear rim setup a 17x11.5+48. After these tires die there should be enough room for a 315/35/17 tire.
Front is the stock rolled fenders with the standard 17x9+45 with a 255/40/17 kumho xs.
Since this rim started life as a 17x9.5+38 and Im running 15mm spacers. The poke of my setup would be the same as a 17x9.5 +22.
Also I'm still on stock suspension. I bought some bilstein pss9 but the rear reservoir are much bigger than stock and hit the inside of my rims so I had to sell the coilovers. I plan to get the koni and ground control setup and lower the can maybe 1/2 to 1 inch.
295s those are some fat tires i wonder if it'll rub on a stock ap2.
kevinboosted
01-30-2013 06:08 PM
bluemetals2k
Member S2000 Classifieds and For Sale
43
07-03-2010 10:32 AM
klns2k
33
11-19-2006 09:12 PM
cjb80
05-16-2003 03:54 PM
Quick Reply: Riceball777 f24 stroker turbo motor flex fuel build
