SOS Stage 1 RRFPR Tuning Help
#21
I took the car out again today after getting the wideband gauge and a boost gauge permanently installed. It was too rich where it was set. I was hitting 7k rpm :11.5 and redline: 11.2.. I backed out 1 turn and 3-4k rpm: 14 and 6k rpm: 13. After that i turned in 1/2 turn and now its hitting 3-4k rpm:13-13.2 and richens 6.5-7k rpm: 12.5 and 11.5 at redline. Seems like the 3-4k rpm is what is limiting me from making it any leaner. I may want to turn it in just a tad to take the 13.2 down to a solid 13. Boost gauge is showing 5 psi at redline.. I live in Colorado so maybe this has something to do with it. Looks like I need to take it out when its darker as it was kind of hard to read the A/F gauge when it was sunny through my gopro.
I am having trouble detecting when VTEC is engaging because it isn't as noticeable as before without supercharger installed. I feel a pretty good power increase at 5k rpm ish and hear the supercharger start to whine a bit. Do you guys notice VTEC to be less abrupt with supercharger installed?
On a side note, the resonated test pipe i installed got rid of almost all my drone. I've been trying to reduce drone by putting sound dampening into the interior with unsatisfactory results. Now it really toned down which is a huge plus!
Adding 1psi more would put you in the sweet spot on your afr/fuel curve. Right now your running lean best down low but too rich in the top end. Running the next pulley size smaller will require you to add just a little more pressure, but put you in a good place down low wile leaning out to a more favorable 12.5 up top so you have a flatter fuel curve. With 1psi more and 1 point leaner up top from 11.5 to 12.5, you will likely see 25whp more peak which is a hell of a return. Your blower efficiency level goes up as well. At 5psi, its barely yielding enough to offset the parasitic losses. 6-9psi is the highest efficiency range for a 1220. At 5psi peak rpm with 11.5afr your making 270-280whp dynojet right now. Just leaning out the top end to 12.5 will give you another 8-10whp, but you cant safely do that as is because you would be too lean down low. So stick with what you have for now, as its the best compromise for safety.
#25
With more testing today I think the fvm may be defective. I was able to hear vtec kick in at around 5800 rpm. Before I was doing 2nd gear pulls and it was mostly fine but doing 3rd and 4th gear pulls showed that I had a lean spike to 14 at 6k rpm. I'm going to contact SOS to see if they can replace the unit.
I also bought the 7psi pulley but gotta work these issues out first before I install that.
#26
#27
Bummer if thats the case. I wonder what the deal is with these units, if there is a manufacturing defect or some kind of initial programming oversight? Anyway, good lesson in street tuning, with using 3-4 gears to help isolate a potential problem in tune. The lower gears just wiz by too quick to get a bearing on anything, certainly when it comes to afr and vtec engagement point.
#28
The neo is a good alternative if you get to that point, as it does everything the fvm does short of adding injector duty in lowered vtec (which I assume fvm does) but is programmable so there will be a small learning curve for you, but is interface adjustable without a laptop (most simplistic programmable piggy back available). I would stick to the fvm though if you can get a working unit. NEO are not that common used, and you will spend $500+ to get a new one with the optional pnp harness, which is really a must in my book.
#29
I understand both engine and compressor rpms are identical through the gears, but isn't actual air movement speed and ultimately more air; increase?
Like weighing in that a turbo won't spool in neutral; so no matter the rpm etc. other things come into play like faster speeds create ram air and overlap efficiency increases etc. (Including -probably the most important- timing)
Soo would tuning the higher gears like 3-4 like on a dyno which usually use; make all the gears as a whole better, because 3-4th are usually the closest to the 1:1 ratio?
So like junky said 1-2 go by to quick anyways but targeting afr's in the higher gears 3-4 will actually work them all because of the ratio?
#30
May have answered my own question because then that would mean a map for each gear, but also weighing in that a turbo won't spool in neutral; so no matter the rpm etc. other things come into play like faster speeds create ram air and overlap efficiency increases etc.
Soo would tuning the higher gears like on a dyno usually use, make all the gears as a whole better, because 3-4th are usually the closest to the 1:1 ratio?
