staylor's turbo build
#51
Dude, sick ass, painful bumps in the road but gratifying build.
This just proves boosting is no easy feat. Im scared to slap on my kit on 91 gas because i know sooner or later im gonna run into fuel pressure issues, clutch slippage/breakage, ring failure, engine rebuild, etc. But all in the name of good fun.
Keep us updated love seeing builds like this. Btw where r u located?
#53
Ill have a build thread soon, hopefully with less bumps in the road since i cant afford all that you went through lol.
Keep it up brotha, ill probably hit u up when it comes to e85 conversion.
#54
Super clean and awesome looking build!!!
I would have done the dump tube a bit differently. It does not help to have it come into the exhaust on a 90* angle like you have. The idea is for the exhaust gases from the dump tube enter the exhaust on the same angle as much as possible. The same way a header merges from 4-2-1 (for example).
#55
#56
Boost creep wont necessarily be the issue but rather a loss of power at top end. Take a look at your dyno graph. Very uneven powerband near the end
#57
Hey dude, sick build!
I have that same Full Blown IM that I am about to swap out with the stock one. I'm turbo charging my car too. Did you find any benefits from the Intake?
I've spend around 10 hours so far sanding the casting marks off, I'm slowly getting there.
#58
Thanks, it looks good so far. I have no proof that it adds power but it does feel better, I changed gear ratios and had fuel pressure problems so never had a good/fair dyno reading to compare them.
MARK AUS S2K (02-09-2017)
#59
So I haven't updated this thread in a while, have the car all back together runing and some more upgrades after all that. I picked up a set of the id 1700cc injectors, advan 17x10 +50 rz2's, spoon calipers, installed my custom baffled fuel tank, custom steering wheel, and found a used full blown diff kit. The diff kit was missing some parts and had a broken case got all the missing parts from dss and found a iron case installed new wheel bearings while chaging the hubs. As for the diff internals it has a etaon tru trac lsd and richmond 3.89 gear ratio. Now just need to get a tune and hope the trans will stay together for a while.
