T1r dual or gernby t1r dual? Supercharged
I have a tts supercharged 07 build bottom end @ 10.1 comp making 16.5 psi.... Making just shy of 450 on a dynapack with a full stock exhaust. Thinking about changing exhausts for fun, some more noise and maybe some power. Between t1r 70mm HFC with there t1r dual 70-em or a gernby with the t1r rear dual option. Or just buying a stock sized test pipe. I will obviously retune the car after changes. Looking for ideas, feed back on these sets ups from other supercharged owners.... Is any of it worth it?
T1R dual was on my radar until I went hytech dual. I bet it sounds great. Regardless test pipe will help a lot with the aggressive sound if your still on the stock cat. You won't notice to much more power though.
Dig the multi point water/meth injection, I also ran with my supercharger.
So your still running the factory cat? If so, thats your biggest plug right now. You could literally pick up 15-20whp+ for $80 by that simple swap on to your factory exhaust. A dual cat back I dont see you picking up more then 10whp and probably less for a hell of a lot more then $80. I would steer away from a Gernby pipe for FI. he didn't design it for that and you risk melting/blowing out the cat portion of the system.
Thanks for the feed back. I'm going to t1r high flow cat and dual exhaust in 70mm and leave my factory header. I really like the idea of meth and originally did it with my stock bottom end. It has had a few leave issues which bother me and make the car less reliable, now on the built 10.1 bottom end the boost has fallen from 17-18 to 16ish and meth really isnt necessary anymore. I have a stock manifold about to go on and I'm pulling the meth system and retuning with the new exhaust set up. Meth leak at the track will ruin your day quick.
