S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
AP1 seats into an 06+
Old 03-27-2017, 05:02 PM
ragtophardtop's Avatar
Question AP1 seats into an 06+
How hard is it to put 00-05 seats into a 06+ S2k? I've seen threads where people trying to do the reverse, and it seems you can swap seat rails and it 06+ seats fit fine in AP1s.
Old 03-27-2017, 07:12 PM
Hfreak's Avatar
I have installed '04-05 AP1 style seats into my 2006, had to swap most of the hardware but very happy with the results.
Old 03-28-2017, 10:18 AM
Nice!
Old 03-28-2017, 10:28 AM
winning's Avatar
the only rail you have to swap is the passenger side the driver side stays the same
Old 03-28-2017, 03:42 PM
Hfreak's Avatar
Yes and no I guess, the drivers rail on the '06+ has a sensor that plugs into the harness that is mounted under the seat. I swapped the rail to avoid any possible future issues but not sure if necessary? Looked like a full forward seat position sensor.
Also, not just the rail on the passenger side, you will also need the upright bracket that attaches the rail to the seat back. It was changed in '06 to accommodate the belt being bolted to the seat. Good luck if you go forward with this.
Old 03-28-2017, 10:00 PM
I'd only be doing the driver's side to accommodate wearing a helmet for AutoX. It sounds like this one is ok to do, the passenger seat is more complicated, correct?
Old 03-29-2017, 04:10 PM
Hfreak's Avatar
The passenger rail has weight sensors for the SRS system and an interface module under the seat, the entire seat bracket is also different. More complicated, certainly.
But like Winning mentioned, you can swap the OEM driver's seat with rails and should not have an issue. I swapped the rail too as to not have an issue with the sensor that is present on the '06+ seats but not sure if needed.
darcyw
07-09-2018 05:12 PM
Gabe826
07-17-2010 10:01 PM
KONcept
03-24-2010 01:40 PM
Rinker
01-11-2009 02:06 PM
Quick Reply: AP1 seats into an 06+
