S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
DIY: Bride Seat & Rail Install
Old 12-28-2011, 01:42 AM
KoketsuCivicSi's Avatar
Default DIY: Bride Seat & Rail Install
I recently purchased a pair of Bride Digo seats and rails and thought I'd do a quick write-up for you guys for future reference. I cannot recall the exact size tools to use at this time, but you will need a socket set and allen-keys for the install. Power tools will make removal of the OEM seats a lot easier. Also, thanks to the guys at WekSos Industries for guiding me towards the correct mounting rails.
Unloading the package:
The mounts on the seat do not align with the rail:
Re-checked the packaging, adapter plates found well-hidden in the box:
Installation instructions and mounting hardware (Top-left for the belt-latch, three rows on bottom-right to mount adapter plate to rail. The two bolts and zip-tied washers will not be used):
Adapter plates mounted (note the lack of space between the mounting points and the slider, patience will be necessary to mount all six bolts):
Hardware for the belt-latch pre-mounted before the OEM belt-latch is installed:
For reference, here's the OEM layout for the passenger-side belt-latch:
OEM seat is held in by four bolts. Here's a picture of the passenger-side with the seat already removed:
Hardware to mount seat rail to the seat:
Under the driver-side seat, the seat-belt harness must be disconnected to remove the seat. There are three mounting points that attaches the harness to the bottom of the seat, detach the harness:
Seats installed. Perfectly clears the doors and glove compartment:
Old 12-28-2011, 06:45 AM
hdoan112's Avatar
nice write up. do you have a harness bar for the harnesses?
Old 02-09-2012, 07:12 PM
F1 blue's Avatar
how do you like the seats after a month+ of time? how big of a person are you and how does the seat fit you?
do they sit any lower (or higher) than the stock seats?
Old 02-12-2012, 09:07 PM
06Estukay's Avatar
+1
Where did you anchor the harnesses? I'm curious to know!
Old 02-15-2012, 07:27 AM
RiceMan's Avatar
what type of rails is that?
Old 02-15-2012, 07:28 AM
RiceMan's Avatar
nvm i see it, it's LH type rails!
Old 02-15-2012, 07:31 AM
RiceMan's Avatar
where did you get the rails from?
Old 03-02-2012, 12:45 AM
Banned
KILLA CAM (The Kid)'s Avatar
Looks like he either anchored them to the bottom of the seats or pulled the plastic piece off until the roll hoops and drilled um inside on the inside of the roll hoops?
Old 04-28-2012, 08:20 AM
DaGou's Avatar
what year is your car, heard 06 and on there are air bag problems?
Old 05-22-2012, 07:35 AM
epan319's Avatar
love these seats
Quick Reply: DIY: Bride Seat & Rail Install
