S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Roll bar garnish separated, rattles
Old 10-30-2016, 10:27 PM
phoenix9999's Avatar
Default Roll bar garnish separated, rattles
The last ~7 years my passenger side rollbar garnish has been separated (the front and rear pieces, that is) and rattling. No more! I'd like to repair/replace this assy and I see a couple of parts on Majestic and similar:
Looking at,
http://www.hondaautomotiveparts.com/...LL+BAR+GARNISH
I see R and L garnishes however I'm unsure which is the driver's side and which is the passenger's side. Suggestions on the part number for the passenger's side hoops?
Old 11-02-2016, 05:05 AM
deception9's Avatar
the arrow in the left hand bottom corner indicates the front of the vehicle. the left side is passenger, driver is right side, #02 and #04 respectively. the multiple options are for different colored interiors. i hope that clarifies things. another thing that gives it away is the seat belt guide assembly.
edti: 84515-S2A-010ZA if you need black. be forwarned: those plastic pieces are meant to be removed as an assembly with the roll bars. removing the plastics from the roll bars will permanently change the plastics. that's why if you are looking for new plastics that don't rattle, you likely want to find the whole assembly together and install that.
arkui0129
02-24-2010 11:36 PM
vanDiemen
02-08-2010 05:36 PM
johnhv
06-02-2007 10:18 AM
nichigo
06-01-2007 12:46 PM
Bassoctopus
08-14-2004 01:10 AM
Quick Reply: Roll bar garnish separated, rattles
