Compilation of Spring Rates
Old 07-31-2007, 01:44 AM
slipper's Avatar
Default Compilation of Spring Rates
How it going everybody.
Im kinda new to the forum and although im a looong time S2000 fan ive never had the opportunity to own one until now. Although im new to S2000s, im not new to automobile and motorcycle motorsports. My current vehicle is an 1997 Acura Integra Type R #122 with a fully built 1.9L N/A B18C5 motor bored to 84mm, Wiseco 12:1 pistons, RM (Rocket Motorsports) rods, RM M24x cams, RM springs and retainers, Hytech 2.0L header, 3" exhaust, and a bunch more.
Since im in my newbie stages in compiling random information and one of those things are sping rate. Heres what i've been able to find so far and please feel free to contribute.
Aloha.
OEM
Brand: OEM
Year: 00-01
Spring Rate: 218lbs front / 290lbs rear
Drop: n/a
Brand: OEM
Year: 02-03
Spring Rate: 200lbs front / 280lbs rear
Drop: n/a
* not sure if this is correct
Brand: OEM
Year: 02-03
Spring Rate: 240lbs front / 230lbs rear
Drop: n/a
* from different source based on published % changed from Honda
Brand: OEM
Year: 04-05
Spring Rate: 256lbs front / 207lbs rear
Drop: n/a
drop springs
Brand: Eibach Pro-Kit
Year: 00+
Spring Rate: 262lbs front / 342lbs rear
Drop: 1"
Brand: Espelir Active Super Down
Year: 00+
Spring Rate: 314lbs front / 392lbs rear
Drop: 1.2 - 1.3"
Brand: Tein S-Tech
Year: 00+
Spring Rate: 300lbs front / 360lbs rear
Drop: 1"
Brand: KG/mm Sport
Year: 00+
Spring Rate: 498lbs front / 548 rear
Drop: ?
Brand: Neuspeed (sport, race?)
Year: 00+
Spring Rate: 280lbs front / 215lbs rear
Drop: ?
coilover system
Brand: Tein Type Flex
Year: 00+
Spring Rate: 560lbs front / 670lbs rear
Drop: n/a
Brand: Tein Super Racing
Year: 00+
Spring Rate: 900lbs front / 900lbs rear
Drop: n/a
Brand: Tein Type N1
Year: 00+
Spring Rate: 1010lbs front / 1120lbs rear
Drop: n/a
Brand: Buddy Club N+ Spec
Year: 00+
Spring Rate: 560lbs front / 448lbs rear
Drop: n/a
Brand: Bilstein PSS9
Year: 00+
Spring Rate: 345lbs + 85lb helper front / 285lbs rear
Drop: n/a
9KEVERYDAY (07-23-2019)
Old 07-31-2007, 04:18 AM
freq's Avatar
Thank you.
Old 07-31-2007, 04:30 AM
mikey k's Avatar
Good idea
Thoug I think you 02-03 OEM figures are wrong. They moved closer together.
My 06 car had the OEM springs tested at 250 lbs front and rear
Nitrons are 300lb front and rear for all years. with 30mm drop
Old 07-31-2007, 05:00 AM
glagola1's Avatar
Thanks Slipper. Good idea.
This should be cleaned up of posts like mine and stickied.
Old 08-04-2007, 03:55 AM
slipper's Avatar
Added...
Brand: OEM
Year: 02-03
Drop: n/a
Brand: OEM
Year: 04-05
Drop: n/a
Year: 00+
Drop: n/a
Old 08-04-2007, 03:58 AM
slipper's Avatar
Anyone gonna contribute?
Old 08-04-2007, 07:49 PM
SimpleMan's Avatar
Found this, add it to the 1st post.
WE NEED A STICKY!
Tein S-Tech:
Fr: 297(5.3) - Rr: 364(6.5)
Eibach Pro-Kit
Fr: 262(4.67) - Rr: 342(6.1)
Fr: 313.6(5.5) - Rr: 392(7.0)
KG/mm sport:
Fr: 398(7.0) - Rr: 448(8.0)
Neuspeed:
Fr: 280(5.0) - Rr: 215(3.8)
Old 12-25-2007, 07:38 AM
Vitt's Avatar
Bookmarking this thread
I am trying to find 2 pieces of info:
1. Does anyone know the length and ID of the ERS springs that are used with Ground Control coilovers (F&R)?
2. Does anyone have any information on the CR spring rates yet?
Old 11-03-2009, 09:56 AM
Saki GT's Avatar
philbert keeps correcting me when I link to this thread , so I want to post this here - the rates listed here are apparently not totally correct - https://www.s2ki.com/forums/index.php?showt...&#entry14070110
Old 11-13-2010, 04:23 PM
jeallen's Avatar
Recent Post on suspension changes, recommended reading:
https://www.s2ki.com/forums/index.php?act=S...50&t=818884&st=
Apex1.0
08-03-2014 01:05 PM
Xene
05-17-2012 06:57 AM
f23power
03-17-2008 04:05 PM
oryanh
06-24-2006 02:55 PM
Quick Reply: Compilation of Spring Rates
