FAQ: The Right Gasoline - S2KI Honda S2000 Forums
LinkBack Thread Tools
Old 04-08-2005, 02:35 PM   #1
Administrator
cthree's Avatar
Default FAQ: The Right Gasoline
91 octane or higher is required due to the high compression of the S2000's engine. Always use Premium gas in the S2000.
Using premium gas is not for increasing performance (not directly) or for giving you extra horsepower. What it does for you is prevent detonation or pre-ignition. Detonation means that the fuel and air mixture ignite at the wrong time due to the high compresssion and resultant heat. This is VERY bad for the engine. The effects of detonation are cumulative, meaning the damage adds up over time. Higher octane gas will be more resistant to detonation and allow your engine to run as intended.
cthree is offline   Reply With Quote
Old 07-07-2005, 08:00 PM   #2
OK, I am a newbie. The third time I put gas in my S2K I filled 3/4 tank with regular (89) by accident. The engine has about 600 miles on it and there was 1/4 tank of 93 still in it.
Would you:
A. Add an Octane booster
B. Drive out 1/4 tank and top off each additional 1/4 tank
c. Siphon it out and dump it in my Chevy 4x4 truck
I am leaning towards B
Budman05 is offline   Reply With Quote
Old 07-08-2005, 05:24 PM   #3
I'd put octane booster right away... don't drive to hard too
BlitzSRM is offline   Reply With Quote
Old 07-08-2005, 05:36 PM   #4
Thanks. I can do that. I'm so used to pumping 40 gallons of regular into my truck, I need to pay more attention
Old 07-08-2005, 05:44 PM   #5
it nice filling up a car that takes a little over 10 gallons huh... and it last for a pretty long time, compared to a truck or SUV.
i think you'll have no problems, the cars will usually knock, when it's super hot out, and your straining the engine. if it's not 100+ where you live, and you drive around conservativly, you should be okay.
Old 07-08-2005, 06:12 PM   #6
Administrator
cthree's Avatar
That octane boost isn't going to do much. There is no problem with what you did. Just run it down a half tank and put 93 or 91 in to the top. It will flush out and the engine can handle it.
Old 07-08-2005, 06:58 PM   #7
So octane booster doesn't boost the octane?
Old 07-08-2005, 07:48 PM   #8
Thanks for the input. I drove it about ten miles today and had no knocking. Of course I didn't push it. I will do a 60 mile round trip tomorrow with no engine strain and top it up with the best I can find. I don't think we have a Sunoco with the real high octane in VA. Do they exist anywhere now, or is it all just BP?
I figure if I don't hear a knock or a backfire, she is running OK.
I love this car
Old 07-12-2005, 06:26 PM   #9
You won't be able to hear most knocking unless it gets really bad. The engine has a knock sensor that will pull timing if it senses predetonation. I'd personally just drive it easy (highways miles are fine) until the tank is nearly empty and then just fill up with a quality premium. I use BP 92 personally since its the best we have in Minnesota, but Sunoco and Chevron are also excellent choices.
S2kracka is offline   Reply With Quote
Old 08-05-2005, 01:43 PM   #10
Gold Member
wwwracer's Avatar
100 octane
i was sic of seeing the takata race harness post. needed to change this up.
wwwracer is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
