Will a 07 soft top with frames bolt into a 00?
Was looking to change out my 00yr soft top with an 07 glass version and was wondering if I will run into any troubles swaping?
I am getting it with frames motors complete so it should fold down properly.
it should do a a perfect swap. but im warning you now that doing top swaps are NOT easy. Try to get some friends to help you out 2 or 3. cause if you do it by yourself, it'll take your HOURS or even days.
I am a body man so I work on cars on a daily basis, when i replaced my rear window It took me seven hours to do it from start to finish. It's not fun and it's not easy. Because your swapping the frame out it should be a bit easer to do. But have help and take your time you will break $hit if you don't.
