Good oil catch can
Good oil catch can
hey guys I was wonder what are some nice baffled catch cans around 100 dollars for the ap1 also where is a good place to install them
I have found 3 that I am thinking about so far what are your opinions
https://www.amazon.com/Primecooling-Baffled-Universal-Aluminum-Reservoir/dp/B01JOMXG2I/ref=sr_1_7?ie=UTF8&qid=1490643851&sr=8-7&keywords=baffle+catch+can
https://www.amazon.com/VMS-Racing-Universal-GUNMETAL-Reservoir/dp/B00T10GXO2/ref=sr_1_8?ie=UTF8&qid=1490643851&sr=8-8&keywords=baffle+catch+can
https://www.amazon.com/Mishimoto-MMBCC-MSTWO-BK-Compact-Baffled-2-Port/dp/B00OBEP51K/ref=sr_1_3?ie=UTF8&qid=1490643851&sr=8-3&keywords=baffle+catch+can
thanks guys (:
thanks guys (:
https://www.amazon.com/Primecooling-...ffle+catch+can
https://www.amazon.com/VMS-Racing-Un...ffle+catch+can
https://www.amazon.com/Mishimoto-MMB...ffle+catch+can
thanks guys (:
thanks guys (:
Saikou Michi makes a good dual can setup with an easy mounting point (next to battery), but its double what you are wanting to spend: S2000 Dual OCC
The first one, is a chinese made aluminum one and can be had for much less:
Oil Tank Baffled Universal Aluminum Oil Catch Tank Can Reservoir Tank BLUE | eBay
In my opinion, it's a very good design. A lot of the cheap oil catch cans are a single tank with the inlet and outlet barbs going to the same place without any baffling, this means it could just suck the oil vapors right out. This one has a spot for a baffle to reduce the amount of oil vapors your intake my inhale, especially if you don't run it vented - which it even comes with a little breather!!!! Next, checking the catch can level, sounds great with the ones with a clear sight tube, until that sight tube gets stained with black ass oils and you can't tell your nice new clean oil at a quick glance. This one has a dip stick, pretty damn clear how much oil is it in with a dipstick.
The coolant catch can combos are a joke, especially if you track. If you happen to be filling the catch can, they are an absolute pain in the ass to drain.
The saikou michi sounds great, unless you actually plan to track your car, then you get a chance to see what a header burn feels like when you need to drain the petcock.
On an AP2 DBW, the Cusco can is great, because we don't have a cruise control module, so it mounts perfectly like factory.
For non-DBWs, I'm not a fan of losing features like cruise control, unless the car is a trailer queen.
Mounting Locations:
For my friends, which I built off of that new baffled catch can (your #1 listing variety), he has the Megan Strut X Brace and an a K&N FIPK, with plenty of room, I used a bar clamp and an L bracket to secure it.
If you have an intake but no brace, then the front cross member makes a good mounting point that's easy to access
Pro Tip:
The tubing it comes with is absolute garbage, under vacuum it's likely to collapse, get some reinforced fuel line or pcv hose from oreilly.
Mounting Locations:
Pro Tip:
Oil Tank Baffled Universal Aluminum Oil Catch Tank Can Reservoir Tank BLUE eBay
Mounting Locations:
Pro Tip:
Mounting Locations:
Pro Tip:
If you vent to atmosphere you have a simpler setup, you can run both lines (with the PCV either drilled out or removed) to one can. The negatives are that you will get some smell from the vented gases, and also it can get a little grimy due to the atomized oil that doesnt get trapped in the can or the filter. Also some believe that the VTA catch can isn't as efficent because it isn't utilizing the vacuum to pull the gases out of the crankcase. That being said the majority of the track guys and in most motorsport scenarios, you will see VTA setups. A VTA setup also will ensure that no oil/gasses will be added back into your air stream which can effectively cause your octane rating to drop.
Read above, you can vent both to atmosphere, or do one VTA and one vacuum system, the benefits can be argued for both, it really depends what you are comfortable with.
yes it just gives you the option of running it vented or not; it comes with the filter and barb or a screw
If I could find universal location to mount this thing, I would just mock up a bracket and make a bunch of them for this can - I'm really impressed with how thought out it is. I'll snap some pics for you guys when I get home
Okay, i just saw another members build s/c'ed. Only the crankvent went to a catch can, the pcv connected directly to the IM.
i would think if anything, run the pcv to a catch can and leave the crankvent connected to the intake arm no? Doesnt the pcv draw more oil than the crankvent?
