Info needed. Opinions. Camber kit
Please explain how tire size effects the amount of camber you have? That makes no sense to me unless you are limited due to the tire or wheel hitting something on the inside and therefore have to adjust the camber. If the wheel is at -2.5 degrees and you change the wheel and tire or just the tire why would the camber measurement change?
Wanting more or less camber is on a 'per application' scenario. Depends on tire compound, width, sidewall and then suspension geometry... Not sure I would be inclined to run less camber on a wider tire.
I need at least --3 in the front maybe more once I take tire temps down. For sure I need some where near -3. Need more info on spc kits cuz I'm skeptical on one bolt holding on my camber adjustment. Seems to me when I hit a pot hole or go off the bolt will get loose. Shine some light on this. I'm considering the js kit or spc right now. Don't want or need any of the baller stuff either. Il run same track times anyways with any of these kits. And that's wat matters haha.
My friend had similar luck.
No slip. Install them properly. Torque the nut to 135LB or whatever it says. Put a lining mark on the plate with a marker so you know if it does slip...and you know where to put it back to.
yup that's an advantage of the js. Its 2x the price too. But it looks cooler. Haha. All u gatta do with the js is bolt it on and it get aligned and BOOM -3 camber everywhere
I've had SPC balljoints on my previous s2k and J's s2 on my current s2000. I prefer the J's.
Keep in mind the SPC pulls the top of the knuckle inward and the j's pushes the bottom of the knuckle outward. Depending on your wheel width/offset you may run into issues with the SPC ball joint.
other ppl might run into problems with the spc and clearance on the shock with high offset wheels. But I'm ok. I can run 18x12 with the right offset right now and like a 285 tire. Gives u an idea on how much room I have to play with.
You can get the Buddyclub front/rear RCA for around $400 total. The front joint allows for a pretty ridiculous camber range supposedly (2-5 degrees).
